Help: Weird Screatching sound when turning
Old Jun 25, 2009 | 08:53 AM
henryw's Avatar
henryw
Default Help: Weird Screatching sound when turning
Hey Guys, newbie here on the site. Well I have a lexus 06 GS300 AWD. When i am making a turn like a 90 degree or u turn, the car makes a loud screatch sound, like metak rubbing on metal or something. Similar to a brake sound when the pads need to be changed. I know its not the brakes bc it only happens when I am turning not when I am breaking. What is the problem and how much would it cost to fix it. I am out of my warranty so cant just go to the dealer and get raped by them. thanks
Old Jun 25, 2009 | 09:31 AM
IXI187IXI's Avatar
IXI187IXI
just because your not braking doesnt mean its not the brakes. id check out the pads to see how they are. does it only happen when you turn in one direction or does it happen when you turn both ways?
Old Jun 25, 2009 | 09:32 AM
ReyRey305's Avatar
ReyRey305
did u get the 3 major recalls done on your car ? (steering rack, fuel rails , and brake calipers)
Old Jun 25, 2009 | 03:28 PM
henryw's Avatar
henryw
It only makes the sound when I turn one way, not the other. yes I have got the 3 major recalls done about 5 months ago
Old Jun 26, 2009 | 04:10 AM
IXI187IXI's Avatar
IXI187IXI
its your brakes
Old Jun 26, 2009 | 09:14 AM
vuiskool's Avatar
vuiskool
Record the sound if its loud.
Old Jun 26, 2009 | 10:39 AM
maying856's Avatar
maying856
if its metal on metal then most likely its your brakes, but you said that it only happens when you turn which puzzles me, and im gonna assume that your car is completely stocks so there should be nothing interfeering....if i were you id take a close hard look at the side that is causing the noise and see if there is anything out of the ordinary. Other then that I have no clue...
richard203
Oct 18, 2021 01:34 PM
Lexalex1
HS 250h Model (2010-2012)
Oct 6, 2010 11:50 AM
dkcivic82
May 3, 2008 10:52 AM
Avid1
Feb 13, 2008 01:20 PM
martialart
Wheels, Tires & Brakes Forum
Oct 5, 2003 10:03 PM
