Just Installed LED DRLs (pics inside)
Old Dec 6, 2008 | 12:46 PM
vietdeluxx's Avatar
vietdeluxx
Originally Posted by kyang91
wow......I think the DRL LED looks great but I might not do it because it will make me lost my high beam and I need to have that in IN. But I think I might do the reverse light bulb and change it to LED because I think that looks sick......
LEDs are definitely brighter and it also eliminate the factory Amber... I also changed the 2 lights above the sunvisors and the trunk. The trunk was so dark before but now it is super bright! I bought those from v-leds.com too.
Old Dec 6, 2008 | 02:23 PM
steviej's Avatar
steviej
I wonder if oncoming drivers will start to flash their lights at you thinking that your high beams are on.
steviej
Old Dec 6, 2008 | 02:25 PM
vietdeluxx's Avatar
vietdeluxx
steviej
Yeah, I was thinking that too but its not too bright during the day.
Old Dec 6, 2008 | 02:29 PM
lextronics's Avatar
lextronics
Originally Posted by junjdm
The DRL's turn off when the headlights turn on.....but there is a little wedge bulb you can replace that comes on when your headlights come on to make it match...
oh....no wonder there are no pics heh thanks
Old Dec 6, 2008 | 03:31 PM
Wronglane's Avatar
Wronglane
During the day,I drive around all the time with my factory HID'S(low beams) on. If I install this kit for the DRL's,can I have them both on at the same time? (4 lights at once)
Old Dec 6, 2008 | 04:27 PM
vietdeluxx's Avatar
vietdeluxx
No it won't... when your low beams are on the small wedge bulb "dummy lights" turn on in that slot not the DRLs
Old Dec 6, 2008 | 05:19 PM
Wronglane's Avatar
Wronglane
"No it won't... when your low beams are on the small wedge bulb "dummy lights" turn on in that slot not the DRLs "
OK,I think I got it now. That "small wedge" bulb you speak of is a 194,correct? Can you reccomend a 194 bulb that will be white or mimic the look of something similar to the 4300 color?
Old Dec 6, 2008 | 05:29 PM
vietdeluxx's Avatar
vietdeluxx
Yeah, I got it from v-leds also... It doesn't match perfectly but it better than the Amber bulb.
Here is a pic of the low beams with the "dummy light" aka 194 LEDs
Old Dec 6, 2008 | 05:37 PM
Wronglane's Avatar
Wronglane
Thats a great pic,I really like the look! I went to the V LED site and there are a few of the hid white 194's. Would you happen to recall the part number for that 194 bulb? Also,are your fogs leds to?
Old Dec 6, 2008 | 05:57 PM
vietdeluxx's Avatar
vietdeluxx
I think these are the ones I got for the "dummy light"
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
As far as the Fogs.. they are just yellow bulbs. I like the 2nd Gen GS look with the factory yellow fogs... Maybe I'll upgrade to 3000k HID kit but I am pretty satisfied with them right now.
Hope this helps!
Old Dec 6, 2008 | 06:21 PM
Wronglane's Avatar
Wronglane
Yes it did help,thank you for taking the time! I am going to order them tomorrow.
Old Dec 6, 2008 | 06:37 PM
dreamerstu's Avatar
dreamerstu
Looks Good.
what happens if you turn on high beams at night?
Does it shows same output as DRL?
Old Dec 6, 2008 | 09:02 PM
junjdm's Avatar
junjdm
Originally Posted by dreamerstu
Looks Good.
when you try to turn your high beam on. it triggers the low beam to turn on. and the high beams go away....
Old Dec 6, 2008 | 09:15 PM
koosflower's Avatar
koosflower
looks great. and how did you change the reverse light?
Old Dec 6, 2008 | 09:51 PM
jspecdan's Avatar
jspecdan
hmm....i'm gonna have to try this on my 2GS
