1 mile remaining on tank?
My computer readout says I have a range of 1 mile left, but the needle is right at the last bar on "E", or just slightly above it. I have had many cars before, I always take it well below the "E". So, in this case, do I truly have 1 mile left, or is it 1 mile before the reserves will kick in?
My favorite gas station is 16 miles away, do you guys think I have enough to get there?
Thanks,
Kevin
Thanks,
Kevin
Hey Kev,
Thanks very much for the link, and research. I did a search for this, but didn't get a hit with my key words.
The result is definitely what I expected. No car will run dry when the needle is on "E".
Kevin
Kevin
Just yesterday I drove my GS350 for another 20 miles after it said I had 0 miles left. Even then, I was only able to put 16 gallons in my tank, and I believe it holds 18.5, so there was still plenty of reserve gas left.
The main reason I do it is I don't like to make stops, but the other is to save fuel. If you watch Motorweek on PBS, they say you should drive with an empty trunk, and < full tank of gas.
also, yeah theoretically with an close to empty tank you have less weight and thus more efficient, but imho that theory is dump like saying throw out the rear seat if you don't need them or avoid eating food before driving
it's a bad idea to have a close to empty tank. especially when you go up and down hill. if the system suddenly run out of gas and the fuel pump tries hard, it overheats easily, and at the same time you can damage other stuff.
just before you say it won't happen, i had first hand experience on my gs400. tank empty and i killed the fuel pump. it's not cheap to repair
what we are all saying is that it's simply just bad for the car to be that low on fuel all the time.
all the potential issues you might/will have outweighs any efficiency you might get from a slightly lighter car. We are not talking about the airplane when flying 5 mins slower can save over 100 million gallons of fuel a year, this is a 18.8 gal tank, there are way too many other ways to save gas than this method.
just a thought
so how does everyone define "filling up"? stop when it clicks the first time, or continue until gas is practically coming out of the hole?
