Low tire Indicator?
Old Oct 22, 2008 | 08:01 AM
SNiiP3R's Avatar
SNiiP3R
Default Low tire Indicator?
Something weird is happening with my car. Got in the car this morning, started the engine and it tells me 'low tire'. I went outside to check tires, all 4 looked fine. I don't have the tool to check the psi. Anyways, it got colder today, could it be the reason ? What do you think I should do? Take it to a tire shop? Or buy that thing and check psi myself?
Old Oct 22, 2008 | 08:06 AM
The G Man's Avatar
The G Man
Lol, go buy a pressure gauge, it only cost 2 bucks
Old Oct 22, 2008 | 08:50 AM
car_fan's Avatar
car_fan
Default Tire pressure is low
I had the same situation. It turned out the pressure were low on all 4 tires. Once I filled up the air, the warning went away.
Old Oct 22, 2008 | 08:55 AM
IXI187IXI's Avatar
IXI187IXI
lol seriously? just take it to a gas station, spend the 75 cents (hell some are free) and just fill up all 4 to be safe and yes its because of the cold weather.
Old Oct 22, 2008 | 09:03 AM
SNiiP3R's Avatar
SNiiP3R
lol alrighty , I'll fill all 4 with air tonight, hopefully it will help. I just thought maybe it was some kind of a glitch... Thanks !
Old Oct 22, 2008 | 09:12 AM
memasterac's Avatar
memasterac
I hve done it just two days ago. Same thing happened with the low tire light came up in the morning. I took it to gas station, fill the air up to 34psi (it was down to low 20 psi but I wasn't able to visually tell) and the light went away.
Old Oct 22, 2008 | 10:13 AM
The G Man's Avatar
The G Man
Every winter we get a post like this, its like clock work
Old Oct 22, 2008 | 11:04 AM
rominl's Avatar
rominl
exclusive matchup
no kidding
more than likely the pressure is marginally low
Old Oct 22, 2008 | 12:26 PM
BurgBoxstr's Avatar
BurgBoxstr
don't forget to check the spare if you have one as there's a sensor for it as well. Some '07s w/ run-flats did come w/ spares however, I think anything w/ r/f now do not have it.
And like clockwork... our next 'annual' question will be about the 'winter' position for the wipers
Old Oct 22, 2008 | 01:07 PM
rominl's Avatar
rominl
exclusive matchup
that donut spare in the trunk also has tire sensor in it?!?!?!?
Old Oct 22, 2008 | 01:34 PM
SNiiP3R's Avatar
SNiiP3R
Update:
So, I went and bought the pressure gauge. Checked all 4 tires and all 4 were fine, 33+ PSI. I then went to a gas station and fill the air up to 36 psi on all 4 tires, the indicator was still showing 'Low tire'. I've tried turning the car on/off, but that did not help. Puzzled, I lowered PSI to 34+ and the problem went away.
Old Oct 22, 2008 | 01:36 PM
Mesca's Avatar
Mesca
Usually it takes a minute or two for the TPMS for the light to turn off. Ugh, still don't understand why they can't tell us which tire has low PSI
Old Oct 22, 2008 | 02:08 PM
cohare's Avatar
cohare
No kidding like the LS I had, all 5 pressures showed up on the screen. I am sure its not that hard...
Old Oct 22, 2008 | 03:38 PM
rominl's Avatar
rominl
exclusive matchup
the ls460 is still pretty silly if you ask me, coz' you have no idea which pressure number correspond to which wheel
Old Oct 22, 2008 | 04:45 PM
SNiiP3R's Avatar
SNiiP3R
lol I've spoke too soon! I just got in the car and the low tire warning is on again. The tires and pressure is fine though. Tire shop? Or take it to a dealer?
