Possible fix to camber problems?
Old Sep 9, 2008 | 06:46 PM
Stormforge's Avatar
Stormforge
executive matchup
Default Possible fix to camber problems?
Does anyone know if H&R Triple C Camber adjustment bolts fix the camber issues on the 3GS? Link below:
http://www.hrsprings.com/products/triplec/
I have not checked to see if there is any application for the 3GS. If there isn't, I can't see why it can't be made for the 3GS (assuming these bolts work). Thoughts?
Old Sep 9, 2008 | 08:05 PM
NAZTY97's Avatar
NAZTY97
i'd be interested to know what's up with these... as i lowered my car, and the camber sux big time!
Old Sep 11, 2008 | 11:15 PM
I8ABMR's Avatar
I8ABMR
my car is dropped relatively low. It sits flush and I have had no problem with alignment at all and I am rolling on falkenfk452 with 10k miles on them. I dont see the need but hey who knows what will happen in the next 5k miles
Old Sep 11, 2008 | 11:23 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
Where do you see a 3GS application? All I see is this:
Code:
Suspension
Stage 	Chassis /
Drivetrain 	Notes 	Approx. Front
Lowering 	Approx. Rear
Lowering 	Part Number 	Sug. Retail 	Photo
Sport Spring 	  	  	1.4 	1.3 	52420 	$ 389.00 Kit
TRAK+ Wheel Spacers
Chassis 	Bolt Pattern 	Center Bore 	Bolt/Stud 	Thread Type 	Spacer Type 	Width 	Notes 	Part Number 	Sug. Retail
	5/114.3 	60.1 	Stud 	12x1.5 	DRS 	5mm 	8   	10656014 	$ 68.95 Pair
					DRS 	15mm 	8   	30656014 	$ 119.95 Pair
					DRS 	20mm 	  	40656014 	$ 125.00 Pair
					DRM 	25mm 	  	5065601 	$ 149.95 Pair
Wheel Adapters
Wheel Type 	Bolt Pattern 	Center Bore 	Note 	Spacer Width 	Part Number 	Sug. Retail
Porsche wheels (5/130 - 71.6 CB) 	5/114.3 	60.1 		25mm 	50695601 	$ 189.50 Pair
Old Sep 12, 2008 | 09:19 AM
Stormforge's Avatar
Stormforge
executive matchup
Code:
Suspension
Stage 	Chassis /
TRAK+ Wheel Spacers
Wheel Adapters
No, I didn't say there was a 3GS application. I was just wondering whether it would be easy (or difficult) to adapt this same application for the 3GS. Since I don't know the technical aspects of the GS suspension, I was throwing this out there for you guys to deliberate whether this can be done or not. If it's just special bolts, it can't be that difficult to make them for the 3GS? All we need to do is contact H&R and ask them if they would make an application for us.
Old Sep 12, 2008 | 09:27 AM
Stormforge's Avatar
Stormforge
executive matchup
So you are saying that after your drop and wheel alignment, that your alignment is still within factory specs? I was under the assumption that the alignment goes out of wack if you lower the 3GS (what you have or lower).
Old Sep 13, 2008 | 09:51 AM
nardeezy's Avatar
nardeezy
Yeah, but I bet your rear camber is less than -2.0 degrees. Your car should corner well. The out of spec negative camber will definitely cause uneven tire wear unless you have a custom alignment performed on the toe and caster to compensate.
Old Sep 15, 2008 | 01:02 PM
KK4510's Avatar
KK4510
Info says for McPherson struts. 3GS does not have this type of suspension.
ipwn
Mar 26, 2013 02:08 PM
SPhoto
Aug 16, 2009 10:48 AM
dRo15
Suspension and Brakes
Feb 26, 2008 11:34 PM
lp_yang
14
Jan 7, 2008 07:02 PM
ki_soarer
Dec 16, 2006 10:56 AM
