Most Annoying Feature
Old Apr 3, 2008 | 06:47 AM
  #46
The G Man's Avatar
The G Man
The clock has a DST and a auto function on it, but its for the old DST B 4 Bush cahnge it, thanks Bush Junior.
The default screen can be set not to default back to the nav.
Old Apr 3, 2008 | 07:39 AM
  #47
RacerX1166's Avatar
RacerX1166
Originally Posted by socalJD
Please enlighten me, what pg in the manual details the digital clock-GPS sync feature. I certainly did not turn this feature off, so shouldn't the factory default be for it to be enabled ? I had the exact same issue in my 2IS.
Am I the only 3GS owner with Nav that had to manually adjust the digital clock for DST ???
My apologies, I thought you meant you had to set your clock from scratch. At the risk of being offensive, I can think of many other things to complain about than having to press a button twice a year for DST.
Old Apr 3, 2008 | 07:40 AM
  #48
RacerX1166's Avatar
RacerX1166
How is this done? I have adjusted this setting and it still jumps to the nav from the backup camera after I'm done backing up. It will also default to the nav if the parking sensors are tripped.
Old Apr 3, 2008 | 07:47 AM
  #49
The G Man's Avatar
The G Man
There is a option on the menu button I think: Time before switching back to nav screen, just select never. This is on the gen 5 version 7.1.
Old Apr 3, 2008 | 09:14 AM
  #50
rominl's Avatar
rominl
exclusive matchup
Originally Posted by flipside909
Ditto. As far as the times being set, it's either set when the vehicle arrives at the port or during PDI at your dealer. I don't see how the clock automatically sets itself unless it's satellite linked to the atomic clock, which is highly unlikely.
actually time does set automatically. quite a few times already when i work on car power disconnected and when back, time was whack. after a few mins it automatically set itself
Old Apr 3, 2008 | 10:05 AM
  #51
The G Man's Avatar
The G Man
Correct that, its in the info button, screen setting, set auto switch back to nav screen to off.
Old Apr 4, 2008 | 05:33 PM
  #52
socalJD's Avatar
socalJD
Negative. Trust me I've tested this on my GS. I keep my wristwatch sync'd to GMT (same as GPS/military satellites), its fairly accurate - it loses a sec/day, so I resync every 30 days. My GS digital clock runs fast, it was 2 mins fast at DST, so I resynched it to my watch. If the GS syncs with GPS, it wouldn't be more than a few seconds off at any given period, let alone be fast by 2 mins. Try syncing the GS clock w/your cell phone (GPS synched), I bet they'll be out of sync in a week...
Old Apr 4, 2008 | 05:40 PM
  #53
socalJD's Avatar
socalJD
No problem. You're not offending me, the thread is about annyoing features, and one person's annoyance is another's nirvana. If you remeber in my post, I confessed that I was nit-picking - when it comes to watches/clocks I'm a bit OCD. Think of it this way, when do you ever have to manually adjust your cellphone for DST or time zone changes ? If you can utilize GPS to time sync a $50 cellphone, why can't Lexus on their vehicles equipped with Nav ???
Old Apr 4, 2008 | 06:11 PM
  #54
ecount00's Avatar
ecount00
This setting definitely will keep it from flipping back to map if you press the audio button etc. I think it still does default to map after you trigger the backup camera for example.
Old Apr 4, 2008 | 07:23 PM
  #55
whlkev's Avatar
whlkev
CL Folding 25,000
good thing i live in AZ, never have to change time
Old Apr 4, 2008 | 08:05 PM
  #56
rominl's Avatar
rominl
exclusive matchup
i didn't say it's going to be accurate to atomic clk or so though, i just said it will automatically set itself to the "right time". i actually said i have no idea how they set the clock, through GPS or something else. but it does set something close
to be honest, i won't care about 2 mins on the clk i my car
as long as it's not showing 5:15 when it's 5:30, i am good.
Old Apr 5, 2008 | 06:19 PM
  #57
ecount00's Avatar
ecount00
That's a nice little upgrade on Gen5 systems. On the Gen4, I have that same button/setting under the info screen and have turned it to off. It keeps the system from defaulting back to the map after you push Audio or Climate etc. But if you go to reverse or the sensors trip, it goes back to map.
Old Apr 6, 2008 | 01:19 AM
  #58
steverhode's Avatar
steverhode
Also after every time you make or receive a call -- I do this a lot -- it goes right back to the map screen, even if you want it to stay on the audio screen.
Old Apr 9, 2008 | 04:39 AM
  #59
NavyDoc333's Avatar
NavyDoc333
The Rotton Egg smell from the exhaust ... (has anyone had this fixed?) I've read about it... and sounds like the dealer usually recommends changing fuels (which I've done) ..
Old Apr 9, 2008 | 12:47 PM
  #60
starstreak's Avatar
starstreak
I hate on my 2007 GS350:
1) Gas button location. Of course they fixed it on the 08.
2) Not having nav but paying full price like I had one. Again, they fixed that on the 08.
3) Ticking sound from engine. BUT that's normal and I can live with it.
4) Not strong seat vents.
