Question: Transmission "S" Mode 6 or 5?
I noticed that i have the option to put the car in 6 in the S mode. I think this gives me better fuel economy. I do not change the gears or anything. Instead of using D I use S and upshift to 6 and drive normally.
ANy comments on this? am i getting better fuel economy? thanks
Staying in 6th gear would give you the lowest engine RPM at the same speed as 5th gear, thus decreasing fuel consumption and increasing efficiency.
If you leave the gearbox in D, it would go up to 6th gear as well. Using the S mode simply gives you control in certain situations, i.e. anticipating to make a pass on the freeway.
markrivers
RX - 3rd Gen (2010-2015)
Aug 25, 2021 11:52 AM
IS3FIDDY
Aug 17, 2006 09:58 AM
