Problem with GS430 trunk
Old May 22, 2007 | 10:43 AM
redwhisky's Avatar
redwhisky
Default Problem with GS430 trunk
Last night i tried to open my trunk. I tried the key fob, the controls from the drop down panel on the dash. I tried with and without the car running.
Has anyone had this happen to them? Not sure if this is a problem. What do you guys think?
Old May 22, 2007 | 11:06 AM
caha14's Avatar
caha14
There are a few threads on this issue. Check that you haven't accidentally hit the "valet only" button inside the glove box. If that is alright, there is a TSIB for some '06 GS300 and GS430 vehicles on trunk motor malfunction. The bulletin # is BO001-06, and your dealer should be able to look it up for you.
Old May 22, 2007 | 11:24 AM
JHStrange's Avatar
JHStrange
I've had a couple of instances where I've opened it but the latch partially closed and then the trunk wouldn't close. Solution: press the trunk release again and it reset. Good to know there's a TSIB out there though.
Old May 22, 2007 | 11:30 AM
redwhisky's Avatar
redwhisky
Hmmm...I dont remember ever seeing a trunk thread.
Thanks a lot guys. Ill check this out.
Old May 22, 2007 | 12:51 PM
chocaholic's Avatar
chocaholic
This is good advice. I hit the button in my glove box accidentally when I first got my car. A few days later I needed to open the trunk and nada.
Took a little while to figure it out.
Tmac334
GS - 1st Gen (1993-1997)
Sep 30, 2018 04:17 PM
sprtn131
Aug 13, 2015 05:48 PM
Z0SICK
Jan 19, 2014 12:44 PM
Rexus300
Jun 7, 2012 11:26 PM
UncivilizedAMD
Mar 22, 2005 11:49 AM
