Check System?!?>!?!?!
i was driving on the highway and i exited then all of a sudden an ! started blinking and on the display on the odo popped up "check system" now i have blinking ! and dont know what is going on..
can anyone help??
The suggestion is the electronics have detected an error and it needs to analyzed to determine what is wrong. This is performed with a service tool.
Your dealer has the tools, expertise and parts if needed. It is warranty supported.
First and simplest, check the insure the fuel cap is tight; a click or two.
mad: :
there goes the warrenty unless i shovel out another 150 for them to re-rewire so the dvd doesnt play in drive if that is the problem in the first place...
Don't worry about DVD hack, that shouldn;t affect the check engine light. If you want to, try disconnecting the battery for ONLY 1-2 minutes... If you do it for longer, you may have to reset all vehicle presets as well as seat-belt buzzer. Not to mention the freaking window/moonroof resets...
