Tips, Tricks, DIY's, & How-To's
Old Apr 6, 2010 | 12:38 PM
  #616
Coolpop's Avatar
Coolpop
LOL. I guess you have to consider the source. He's the same idiot who said he doesn't even listen to the radio because he wants complete silence when he drives.
Old Apr 6, 2010 | 12:49 PM
  #617
rominl's Avatar
rominl
exclusive matchup
guys, either take it to pm or stop it. do not make me start removing posts
Old May 8, 2010 | 04:37 AM
  #618
Coolpop's Avatar
Coolpop
Finally got the seatbelt chime to turn off. The directions given by Eternity3G are great but they didn't seem to work for me...so...I made one minor change. I held the ODO button down for 30 seconds instead of ten. Worked like a charm.
Old May 8, 2010 | 09:23 AM
  #619
kitphat's Avatar
kitphat
Do u have a diy to turn the drl off??
Old May 8, 2010 | 04:10 PM
  #620
carlos2003's Avatar
carlos2003
Hi guys
I've problem with my subwoofer in GS III 2006 Mark Levi. I cant enter the Audio to change F, R, W settings. I press the Climate and Audio buttons and turn on/off the light 3 times. Can you explain me to get in Service Mode Audio?
Old Jul 10, 2010 | 10:21 AM
  #621
nalonrico's Avatar
nalonrico
hi ,friend i ll tell you that i made the steps just like you post it more than ones & there is no way to reset the oil maint light,please can you help ? ,what appear in my odo meter is( OIL MAINT REQD ) thanks
Old Jul 11, 2010 | 06:09 AM
  #622
passnu2's Avatar
passnu2
It works, make sure your not on Trip A or B:
Reset Maintenance Required Light
1. With your car OFF, place your key in the ignition and turn to ""On"". Do not start the car.
2. Find the odometer button and press until it reads the total odometer setting, (not the Trip A or Trip B setting).
3. Turn the key to OFF.
4. Place your finger back on the odometer button, press and hold. At the same time, turn the key back to ""On"".
5. Hold the odometer button in until the MAINT REQD light goes out...should take about 8-10 seconds.
Old Jul 21, 2010 | 12:45 PM
  #623
RenatUSSR's Avatar
RenatUSSR
Does anyone know how to change puddle lights in side mirrors? DIY ?
It was easy in my IS250 to change by removing the mirror.. like this - https://www.clublexus.com/forums/2015986-post43.html
Old Jul 21, 2010 | 02:36 PM
  #624
CAK 500's Avatar
CAK 500
You're going to need to take the door panels and mirrors off before you can get to the puddle lights. This DIY shows the details. Removing the panels is simple, but pay close attention when putting them back on. It's easy to misalign the fasteners that hold them to the door.
Old Jul 23, 2010 | 01:45 PM
  #625
RenatUSSR's Avatar
RenatUSSR
Thanx! As shown in the first page of the thread? https://www.clublexus.com/forums/gs-...iy-thread.html
Just by pulling the mirror would be not enough?
Old Jul 23, 2010 | 03:48 PM
  #626
CAK 500's Avatar
CAK 500
Unfortuneately no. You will have to open the two halves of the mirror covers to access the bulbs, and in order to open them you must first remove the door panels and then the mirrors. Sounds more complicated than it is, really. Just study the DIY first.
Old Jul 26, 2010 | 10:10 AM
  #627
RenatUSSR's Avatar
RenatUSSR
CAK 500, Thanks comrade
_______________________________
On the GS, if your headlights are on, and you use the windshield washers, the headlamp washers will automatically activate once.
I used this DIY - http://my.is/forums/f64/isx50-switch...ashers-341199/ on my previous IS250 to solve the problem.
Is it possible to use the same DIY on GS ???
I want "the only time the headlamp washers will activate is when you press the headlamp washers button.."
Old Aug 2, 2010 | 04:43 PM
  #628
cunningham's Avatar
cunningham
Originally Posted by sherif2
If the ignition is off, and the doors are closed, you cannot do step 3. unless you push the START button. You simply cannot do step 3. I have a 06 GS300 and the seatbelt buzzer kills me. I can;t stand it.
So i tried it different ways and no luck. What is the solution?
Thanks in advance.
just did the mod to my 06 gs300 and it worked, the post is just missing a step.
get in and shut door
turn engine on, set odo/trip to odo. may want to make sure it is set to odo using steering wheel also, and then turn off engine.
take foot off brake, press start button twice (dont turn on engine)
hold down odo button for about 10 sec while you also put on your seat belt.
from there, follow the post
Old Aug 2, 2010 | 08:41 PM
  #629
shahzad's Avatar
shahzad
Hey guys, sorry too many pages to read
How can I change my cabin air filter, and Air intake filter
I'm going with the KNN air intake filter, but You guys think its okay to use a after market cabin filter?
Old Aug 2, 2010 | 11:56 PM
  #630
rominl's Avatar
rominl
exclusive matchup
https://www.clublexus.com/forums/gs-...ere-first.html
# DIY Change Cabin Filter Example
# DIY Change Cabin Filter Additional Info
engine air filter, it can't get any simpler. pop the covers in the engine bay (passenger side), undo clips, pull up air box cover, change filter. i did mine is 5 mins
