fun in the snow
Just have to watch out not to speed, because the braking is the same
or worse than everybody else and to watch for the other cars because
sometimes they go ice skating around you.
I had to shovel every inch of the path, from 15 feet behind my car, across the street, all the way to the garage. I ended up just parking it on the driveway. Needless to say, I took the 4Runner to work today!So here is my question: Have any of you had a good experience with all-weather tires in the snow on GS430?
I've come to realize (through the planning of a home theater) that OWNER/ENTHUSIASTS are most often a better source of information than salespeople... even good ones.
Question 2: What 18" snow tires would you recommend?
all season tires. Snow tires are much better, but with RWD it is much easier
to get stuck. Not being able to go up icy hills is a horrible feeling. The other
day some clown in a Beemer held up traffic for 1 1/2 hours because he could
not go up a hill
18'' tires are usually too wide for snow anyways. You may want to go down
to 17'' and get Blizzaks for those, but my feeling is even the 225/50/17's are
too wide...
Others who have had 430's have shared their experience if you do a
search. I respectfully disagree with some of their opinions. I think RWD
cars should be parked when it snows more than 4 inches.
GS430 in the snow, get snow tires. Don't push your luck with the all seasons.
One of my friends said snow tires with RWD was enough, but the other day
he got stuck in the parkway under 6'' of snow
I suppose I am asking a very broad question... Without a doubt (in my mind) snow tires will be much better than all-season, regardless of size. But most of the older posts I found on this site refer to 16" vs. 17" on the older GS models. I haven't found a discussion of 18" snow tires, yet.
to help. Logic says the 245/40/18 is too wide, but I perfectly understand why you
don't want to go with 17's. I upgraded to 18's in the middle of winter and the dealer
justifiably gave me a warning that snow/rain performance may suffer.
You may be one of the first to try the 18'' snow tires, since previous GS's best OEM
setup was 17''. You may want to ask around on the TireRack forum for feedback,
but they might tell you what you already know.
So far he has been correct--unless I count not being able to pull into my own driveway without a running start!
performance too much. They haven't been tested strenuosly though and are
just starting to break in.
Next winter I may get winter tires if I have trouble, but so far no problems.
GS430, VDIM and snow. You may want to look at their assessments and see if you
agree with them. There may be other suggestions there as well, like adding weight
in your trunk?
The GS430 is a marvelous elite car, but 3 months out of the year it may not be able to
go everywhere you'd like. I'm jealous 9/12 months
Also, before I forget: Thank you, marshmallo!
You're welcome and good luck with whatever you decide to do!
I had an experience very similar to yours a few weeks back. I got stuck backing out of my garage in about 5-6" of slushy snow. My driveway is barely on an incline, so I can't imagine what would happen if I had to actually drive up a slight hill....the car would probably slide backwards! All the praise for VDIM and TRAC had me convinced that I would be fine driving in most conditions I encounter. Boy was I wrong. The RWD GS is worthless in snow. Even with all the driver aids enabled, the back end will loose traction and break loose quite easily. By comparison, my '97 528i felt much more stable and secure and performed better in snow and rain. Heck, even our lowly '02 Civic on all-season Kumho tires does 10x better than my GS, without the help of traction control or stability control. Granted, it is a FWD vehicle, so that helps quite a bit.
FWIW, I swapped out my stock Continental tires for Pirelli PZero Nero M+S tires, which are highly rated for snow traction, even though they are only all-seasons. On top of that, I always enable the snow mode on my transmission and have penty of experience driving in snow/ice. Still, if we get more than 3" of snow, the GS is completely useless. Snow tires would help, but I'm thinking the GS is more of a "fair weather friend" at this point. Needless to say, I went out and leased an '06 Pilot EX-L the other day. It does great in the snow and also fixes my other main gripe with the GS, which is cargo capacity. The narrow opening of the trunk and the lack of fold down rear seats make carrying any large box or odd shaped item nearly impossible in the GS.
I will say that I do still love the audio system and creature comforts of the GS, but I'm not loving it the way I did when I bought it.
