Seat memory problem
Old Nov 15, 2005 | 02:33 PM
p34m23's Avatar
p34m23
Default Seat memory problem
Has anyone had a problem with the seat memory saving the correct position? Mine will save the position I adjust to but lose it after I turn off the car.
I'll be taking it back to the dealership for a fix, just curious if I might be missing something?
Old Nov 15, 2005 | 03:06 PM
lexuslover's Avatar
lexuslover
MultiTasking Mom
Did you hold the memory button and Set button together long enough until you heard a beep?
Old Nov 15, 2005 | 04:41 PM
rominl's Avatar
rominl
exclusive matchup
yeah you have to hold the set and the memory number until it beeps and finished beeping
Old Nov 15, 2005 | 05:32 PM
SGT's Avatar
SGT
Also, I believe the car has to be in "P" (parked) for it to work.
On page 201 of the manual:
Conditions for memorized position activation
-Engine switch in “IG-ON” mode and selector lever in ”P”
position, with the vehicle stopped.
-Engine switch in “OFF” mode and within 30 seconds of
opening front passenger’s door.
If any seat position memory switch is pushed while one of the
memorized seat position profiles is being activated, the
operation will stop.
To activate the system, push the desired button (“1”, “2” or “3”)
again.
The seat position memory control system cannot be operated
while the vehicle is moving.
If the vehicle’s battery is disconnected, the computer’s
memory will be erased and the memorized positions will have
to be set again.
Old Nov 15, 2005 | 08:17 PM
rominl's Avatar
rominl
exclusive matchup
again.
to be set again.
yes, in my 2gs it has to be in P or stopped. basically if you dont' hear the beep, it's not working
forthewin
Sep 15, 2015 06:52 PM
matts6887
RX - 1st Gen (1999-2003)
16
Nov 17, 2014 08:19 AM
Nexifer
Oct 3, 2012 02:40 PM
Baby ///M3
Sep 24, 2011 08:22 PM
