IPA Question
Old Feb 22, 2005 | 09:19 AM
ny888's Avatar
ny888
Default IPA Question
Will the IPA help when you're parking into a space with concrete block barriers and high curbsides ?
Does everyone know what I'm talking about ? How many times have we scraped the bottom of the front bumper when pulling into a parking space because the clearance between the street and the curb was higher than expected ?
Old Feb 22, 2005 | 12:43 PM
frebay's Avatar
frebay
you are SOL if there's a high curbside or side-walk, only detect things that are higher like lampposts or other cars.
Old Feb 22, 2005 | 01:20 PM
Rockville's Avatar
Rockville
Default Intuitive Parking Assist
It scans rearward up to 40" in the center of the bumper and 20" off the corners while in reverse . It does not distinguish the height of an object. It scans forward the same way when you are moving forward. It also figures whether you have clearance on your last pass and gives you an OK to pull out. The option code is WO. It is $500. It would need to be a pretty tall curb to save the chin spoiler. I don't have any with that option so I can't experiment with it. It overlaps with the rear backup camera in some ways but gives an audible tone that gets faster as you approach the object. You could use it blindfolded in a way. Some owners have injured their front bumper corners when backing up because the front sonar turns off in reverse. The tones from the front and rear sensors are slightly different. Hope that helps.
Old Feb 22, 2005 | 02:06 PM
ny888's Avatar
ny888
Thanks Rockville - that helps.
swat1727
Jun 28, 2019 07:39 PM
hube
Suspension
Jan 16, 2015 11:47 AM
JDMmuscle
Nov 25, 2010 12:10 PM
astrotoy
Aug 6, 2008 05:46 PM
wizbill
Dec 26, 2006 07:49 PM
