did lexus forget to put lights in the trunk?
Trunk Light with Switch on Right Hand Side of Trunk
Originally Posted by frebay
or am i missing something.....at night it's totall pitch dark in the trunk...can't find anything for the life of me.
I'm not sure if the switch is left on does the light goes out when the door is closed or not?!? An easy test would be to turn on the light, close the trunk and then go to the back seat and look through the pass through into the trunk area.
Lexus Connoisseur
Or you could climb inside and see if it goes out.... You can try out the glow in the dark release handle too......By the way about the light in the refrigerator, does that go out when the door is closed???
Lexus Connoisseur
The factory trunk light is still dim and useless because it illuminates from one side. Once you put something in the trunk it blocks all of the light to the left side of the trunk.
Here is my solution.
https://www.clublexus.com/forums/sho...+light+2thfixr
