I've been working through numerous issues on my Lexus GS450h. One of the items that needed to be replaced was the Brake Actuator. I purchased the part new from a Lexus dealership, and had it installed by an independent Lexus shop.
That said, I now hear a "chirp" from under the hood when I apply pressure to the brake pedal. It sounds like a burst of fluid flowing through a valve. My question is that sound normal? Does it indicate a problem? This shop has been extremely difficult to deal with, and I honestly don't trust them at this point. Curious if this indicates a problem.
I would take it to the dealer and have them diagnose it properly. I had ABS module / Brake Actuator go out on my 460, they are similar to the 450h. But I did it the other way around. Bought OEM elsewhere but paid the Lexus dealer to install / program it professionally.
Make sure you use Toyota DOT 3 fluid. DOT 4 absorbs more moisture from the atmosphere, and get a new brake fluid cap, it helps keep moisture out, which is bad for the brake Actuator.
Did they use a scan tool to bleed the abs module? The scan tool manually activates the ABS module by following a specific bleed sequence to push out air. If just a normal brake bleed was done, then you might have air in the ABS module, which could be causing the noise.
Could have an air pocket in the system. Did the garage purge the abs system? Any good scan tool should be able to do a abs pump pressure release, by opening the pump.
