08 Lexus GS350 issue when cold
Hi everyone
Hoping someone can help me out I have a 2008 Lexus GS350 RWD. I recently did a custom exhaust axle back system. When the car is cold when driving the rpm goes all over the place when u let go of the gas. As soon as the car gets to normal temperature it goes back to normal. I live in Canada so it does get cold here. Anyone know what would be the issue?
Hi, I am experiencing same issue. Mileage on '08 GS350 AWD is 198,000kms. I too live in Canada and it especially does that when heater fan is engaged.
Once car reaches normal operating temperature it settles down. When cold it will rev higher upto 900 rpms and brake pedal needs to be held firmer when sitting at a Red Light
Thanks ACE
Seeing you have similar year and model, have you ever had car not start on you....Start button light orange, battery tested fine so did FOB.
I depress pedal and brakes light come on so not brake switch, dash just flickers once then goes dark. Doesn't even go to ACC mode.
Do you think unplugging battery would reset that??
Not sure if Immobilzer is activated
Thanks ACE
Thanks ACE
That fixed my issue.
t's a cheap little batter and easy to change.
Try that.
So issue found....Power Source Control module under passenger glove box gets damp especially when left overnight outside.
small space heater on passenger floor for 4 minutes to warm up the area and its starts right away no issues.
Need to access this unit to check for moisture in the area that must be recurring. Any ideas how to remove a glove box properly on 2010 GS350?
Hugh9591
Nov 30, 2019 09:03 AM
sprtdsgnGS
May 7, 2015 02:22 PM
