Low beam projector replacement
Old Jan 12, 2026 | 01:52 PM
allarmees's Avatar
allarmees
Default Low beam projector replacement
Has anyone tried to replace the low beam projector lens. Just replaced the bulbs because old ones were really dim and one occasionally failed to even ignite but the new bulbs don't even seem that much brighter than the old ones. I just got my headlights polished as well so the plastic is super clear. I'm thinking of replacing the projector lens. Does anyone have any experience with this? Is it worthwhile to get an LED replacement lens instead and ditch the HIDs altogether?
Old Jan 13, 2026 | 05:01 PM
skur's Avatar
skur
I looked into it and tried 4 brands, these by far were the brightest. Pretty nice upgrade.
https://ebay.us/m/bacJc1
Old Jan 14, 2026 | 09:24 AM
allarmees's Avatar
allarmees
Thanks but I need help with the projector lens itself, bulbs are fairly easy to find.
Old Jan 14, 2026 | 09:57 AM
Consider
https://auxbeam.com/products/d4-d4s-...bulbs-gd002318
https://www.vleds.com/shop-applicati...ight-pair.html
You CAN replace the projectors but this is a highly involved project you'll be cutting, modding, painting, gluing. Plus it's unlikely you're going to get a large improvement, bang for the buck by putting in a bright LED is much better.
Auxbeam is straight up lying about specs, VLEDS says 5000 lumens which is accurate that will give you 80-100% more light versus stock. Auxbeam will be about the same.
Old Jan 14, 2026 | 11:10 AM
allarmees's Avatar
allarmees
Originally Posted by LeX2K
Consider
Okay thank you for the information but the thing is that it's illegal in my country to replace HIDs with LEDs without having a certified LED projector lens, because of how the light reflects it will most likely blind other drivers (or so I'm told that is the main issue here). That's why I was considering getting a certified LED projector lenses with good bulbs.
Old Jan 14, 2026 | 02:05 PM
LED bulbs for low beam is illegal most everywhere in any kind of housing not just projectors. Doesn't mean LED bulbs produce bad beam pattern in all cases. If you want to custom modify your headlights that's a whole other level of project and you may not improve output at all, will need to research what projectors fit in your housings and have better output.
Properly designed LED bulbs do not produce glare or other issues as seen here, but honestly I'm tried of trying convince people that have never tried LED bulbs themselves.
Old Jan 15, 2026 | 10:19 AM
allarmees's Avatar
allarmees
Oh I'm very much pro LED and I really do hate that it's illegal to modify them for street use. Getting stuck with an idea because of a personal preference is something that never bothers me, however legal issues, don't really mess with them.
Old Jan 15, 2026 | 12:39 PM
Is there enforcement where you live? Here you will never get pulled over unless you do stupid lighting mods like purple headlights or other obnoxious in your face dangerous things.
Old Jan 16, 2026 | 06:33 AM
allarmees's Avatar
allarmees
Not necessarily but I don't feel like I want to switch the bulbs for yearly inspection.
EriQ
Aug 1, 2023 12:57 PM
MamaK55
Mar 18, 2022 10:01 AM
losiglow
Jul 19, 2020 08:31 PM
99LSprobs
Jul 12, 2018 11:13 AM
sparta3993
Jun 6, 2016 04:18 PM
