TPMS relearn problem.
Old Nov 15, 2025 | 08:02 AM
vadimgal's Avatar
vadimgal
7th Gear
Default TPMS relearn problem.
After replacing with the winter tires which have another 4 sensors I am tying to reset TMPS LIGHT using Autel TS508 tool and the the second position of the bottom under glow compartment. Should I try to RELEARN or PROGRAM SENSORS ?
Thanks for any advice.
Old Nov 15, 2025 | 09:03 AM
mspearl95's Avatar
mspearl95
probably program sensors. the ID of each TPMS sensor has to be recorded in the system.
Old Nov 16, 2025 | 11:12 AM
lexo98's Avatar
lexo98
Depends on what kind of sensors you are installing, but if the sensors them selves are already set up for your year, make and model you will need to use the relearn option so that you can enter those id’s into the ECU
Old Nov 17, 2025 | 03:52 PM
goin2drt's Avatar
goin2drt
Are you installing sensors that are already PROGRAMMED for your year, make and model? If so then you are RELEARNING. If you have "programmable" sensors and they are NOT Autel you will not be able to PROGRAM them. That tool only programs/clones Autel sensors.
DanDanDanDaaaaaaaaan
Jun 25, 2025 08:46 AM
rygar
16
May 22, 2024 08:20 PM
RayKnight
GS F (2016-present)
May 11, 2017 05:31 AM
Myrix
Wheels, Tires & Brakes Forum
Jul 5, 2016 08:59 PM
gstern1994
Sep 29, 2014 05:38 PM
