Intermittent starting issue
Old Oct 10, 2025 | 02:03 PM
mainsoda's Avatar
mainsoda
Default Intermittent starting issue
I've had it happen a couple of times since I got my 2008 GS350, I push the start button, the car turns over and then doesn't start. I try it again and same thing then I try it again and it starts normally.
Then today I went on a 30 minute trip, went to start the car after a 10 minute stop and two times in a row the car clunked and didn't turn over.
Then it did the turn over without starting about 5 times then it started normally.
Made me nervous.
You guys think my starter is going?
Old Oct 10, 2025 | 02:56 PM
mspearl95's Avatar
mspearl95
How’s the condition of your battery?
Old Oct 10, 2025 | 06:28 PM
mainsoda's Avatar
mainsoda
A good question, I have a tester. I will run it though it's paces.
Old Oct 11, 2025 | 03:34 AM
Bserch's Avatar
Bserch
Default Starting and stopping
Made me nervous.
Hi 👋 I all so own a lexus gs 350 awd have you checked your battery have you checked for codes it could be the starter it may not all so check your fuel pressure sensor these cars are know for that I have had this issue too check for codes good luck 😉 👍 😀
Old Oct 11, 2025 | 07:41 AM
EtinsBane's Avatar
EtinsBane
3rd Gear
Hey guys. This is a topic that was discussed at great length in another thread. I will try to find a link and post it here. But, until then... Your intermittent starting issue may likely be due to a failing or faulty fuel pressure sensor. I went through this exact issue with my '07 GS 350. Fortunately I know a Lexus mechanic and was able to have the diagnostics done in my driveway and skipped the outlandish dealer fees. The fuel pressure sensor is o. A 5V circuit that wont let the motor run if it doesn't sense correct pressure.
Its a $35 part. Solved all my problems. Good luck gents. Hope that helps.
Old Oct 13, 2025 | 03:01 PM
mainsoda's Avatar
mainsoda
No codes at all.
Checked my battery, checked out fine.
I replaced the battery in my key fob thinking it may be a transponder not getting a proper signal, and so far it hasn't stuttered once.
I also bought a fuel pressure sensor just in case, thanks for the great tips guys.
Old Feb 14, 2026 | 10:28 AM
GS350OwnerCANADA's Avatar
GS350OwnerCANADA
No codes at all.
Hey there, so the new keyfob battery worked then?
GregoryNP
Oct 11, 2025 07:36 AM
djspawn00
Mar 22, 2012 10:31 PM
KILLERGS4
Oct 14, 2009 07:35 AM
vuman1
Dec 22, 2007 02:31 PM
Alexusoftime
May 16, 2006 11:46 AM
