Steering wheel locked car won’t start
Old Aug 8, 2025 | 07:11 PM
Mamalisk's Avatar
Mamalisk
3rd Gear
Default Steering wheel locked car won’t start
My car would not start the other day and was giving me a warning light that said my steering wheel was locked. I cranked the steering wheel so that the wheels the tires were straight. I replaced the key fob battery and the car still will not start. It would go into accessory mode and then it wouldn’t. The lights are working. The battery is fine. All of a sudden I hear a clicking sound under the hood. I was able to get the clicking sound, stopped by unlocking and locking the doors with the manual key. Now the start button will not even work. Can somebody help with some advice?
Old Aug 8, 2025 | 11:17 PM
skur's Avatar
skur
What codes are being thrown? That will help a lot.
When you turn the ignition on do you hear the steering lock trying to disengage? It sounds like a "zzzt". When you close the door with the ignition off do you hear it trying to engage? If you're able to, try wiggling the steering wheel left and right as you turn the ignition on, it might disengage the lock bar.
Old Aug 9, 2025 | 02:26 AM
Mamalisk's Avatar
Mamalisk
3rd Gear
I wiggled the steering wheel left to right and got it to go forward so that the tires are facing forward. How do you use the OBD2 with a push button a push start the interior lights were still going on the fan was going on and then there was a clicking sound. I unlocked and locked the driver side door six times with the manual key and that stopped the clicking sound, but now the car won’t start. I replaced my key fob battery and I’m thinking maybe it’s something to do. It’s not connecting with the ECU now I don’t know.
Old Aug 9, 2025 | 06:04 AM
mcomer's Avatar
mcomer
The symptoms are pointing to the main 12 volt battery being low. Try a jumping the battery and replace if that cures the problem.
Mamalisk
RX - 3rd Gen (2010-2015)
Aug 11, 2025 10:51 AM
Evanatl
Oct 1, 2017 03:28 PM
hoaho
Jul 21, 2016 09:06 PM
dt3g
Nov 14, 2010 07:40 PM
ayonnebay
Mar 24, 2010 07:19 PM
