No reverse gear?
Old Feb 24, 2025 | 10:59 PM
dirty300's Avatar
dirty300
6th Gear
Default No reverse gear?
I haven’t driven the car in about a week. Left my driveway went to store parked and the reverse gear would not engage when i selected R. I don’t feel any pressure or vibration when i press the gas pedal. It won’t go past 2k rpm in park or reverse. When i put the car in drive it takes and shifts fine. Drain and fill & filter a month ago and the car has been fine no codes. Any ideas?
06 gs300 awd.
Old Feb 25, 2025 | 02:42 PM
Oro's Avatar
Oro
06 gs300 awd.
Did you check teh fill level w/the car running? What filter was used - in other Lexus cars we’ve seen aftermarket filters clog/restrict atf flow enough to cause running problems.
Old Feb 25, 2025 | 04:03 PM
dirty300's Avatar
dirty300
6th Gear
Yes the fluid level was checked at temp and drained all excess then tightened. Filter is Oem replacement
Old Feb 25, 2025 | 04:12 PM
dirty300's Avatar
dirty300
6th Gear
This video shows the issue I’m having. Park won’t rev past 2k rpm reverse as well. Noticing my mirrors are not aiming down when I put the car in reverse as it should.
Troels
Apr 3, 2023 02:48 PM
JAndersson
25
Jul 3, 2020 02:55 PM
abaitedcat
May 21, 2019 11:30 PM
GreatWhite
Jan 19, 2011 01:48 PM
