Car doesn't move, Code P1780
Old Dec 23, 2022 | 08:12 PM
BingoBango's Avatar
BingoBango
2nd gear
Default Car doesn't move, Code P1780
Howdy y'all, I have a 2001 gs430. It has a p1780 code for pnp switch. I've driven it 3 times in the last 3 months due to it behind kinda clapped and blowing out the radiator.The first time, it needed a lil extra gas to get moving. Last times I drove I had to bounce off limiter to get it moving, and now it doesn't move. The PRND32L all light up when going through all of them on the cluster. All I've done is add ATF cuz dude said it was almost empty, and just ordered a new switch. Engine is good, no other code other than that. Could this really keep it from moving at all? Or is the trans toast?
Old Dec 26, 2022 | 04:15 PM
Raven01750's Avatar
Raven01750
"Ordered a new switch"? Which one Please. The code seems to point to a switch in the transmission.
Now I don't want to disparage anyone. But I use the owners manual and check the fluid levels myself. Step one. I'm assuming that the car ran fine when the ATF was almost gone. Added ATF and problems start. Hmmm.
Paul
Old Dec 27, 2022 | 04:36 AM
BingoBango's Avatar
BingoBango
2nd gear
Paul
The PNP switch on/in the trans. That's what the code was for so figured I'd try that. As for the ATF, should I drain some out then? It wasnt perfect before adding more. Still took way more gas and time to get it moving than any other car I've driven, and reverse never worked.
Old Dec 28, 2022 | 07:47 PM
Raven01750's Avatar
Raven01750
"Should I drain some out"?
That I cannot tell you. But here is the procedure for checking ATF Fluid level. You'll be better served by checking yourself just to know for certain if the transmission is over filled.
Paul
Kaianuanu
Oct 1, 2025 04:20 AM
jasawh
Feb 24, 2018 06:29 AM
romycha1
Jun 15, 2010 05:05 PM
simons2k
Sep 10, 2009 08:03 PM
mungrin
Jun 24, 2007 08:36 AM
