View Poll Results: What should I do
Replace the radio
33.33%
Replace the ac
33.33%
Get new suspension
100.00%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
Help
Old Jun 15, 2022 | 06:06 PM
300J's Avatar
300J
1st Gear
Default Help
Just purchased a 98 gs300 200+ miles
the radio doesn’t work I have no idea why, I’m still getting voltage from the wire. The radio doesn’t even light up. Also I took the radio out to look at it and now my AC won’t blow. I hear a scraping noise on my front right tire whenever I hit a little dip.
And whenever I speed up to about 60 my steering wheel shakes violently.
Old Jun 15, 2022 | 11:43 PM
melac1's Avatar
melac1
If the tires are fine it sounds like the front right spring is going. The replacement is not too bad of a job if you find just the one.
Old Jun 16, 2022 | 10:54 AM
DMPesso's Avatar
DMPesso
I can’t imagine having a car with no ac if it’s very hot where you are. That would be number one choice. However you can’t compare the cost of a used radio off eBay or a small repair to fix the ac compared to suspension which is usually $1000+ after labor
Old Jun 17, 2022 | 08:22 AM
firelizard's Avatar
firelizard
Fix your suspension because that's a safety issue. Go to a mechanic.
Old Jun 25, 2022 | 04:33 PM
Slogathor's Avatar
Slogathor
5th Gear
firelizard has it in spades. Now not saying all three need to be addressed, but I would just work the list from bottom to top.1 Suspension is safety. 2 AC so you don't show up to work stinky. 3. radio.... you'll have listened to your engine and get a solid grasp of what normal car sounds are while you're saving up for this one.
jebkutach
Mar 21, 2019 05:51 AM
vince93x
GS - 1st Gen (1993-1997)
Mar 11, 2013 01:38 PM
dwoot415
Jul 13, 2012 10:41 AM
ITgeek
Sep 16, 2008 09:49 PM
imjohnphan
Dec 25, 2007 09:59 PM
