Got a flat. Now Crazy wobble at 50+mph
Old Mar 18, 2022 | 08:12 PM
Frankn's Avatar
Frankn
Default Got a flat. Now Crazy wobble at 50+mph
Ok so I got a flat on the , pulled over as soon as I noticed. Now the car feels like the rear subframe is steering itself over 50mph and it ends up being a crazy wobble going left and right. Truly feels like the rear of the car is going to pass me haha
Drives normal as far as I can tell under that speed.
I have a 4Runner of the same year (2000) and had the control arm bushings go bad and it felt pretty similar but not as bad. The bushings don’t have to be very visually beat up to cause scary problems I learned.
I did a little flex testing but I don’t know what healthy bushings look like on our cars.
On the plus side it could help initiating a drift haha
Old Mar 18, 2022 | 10:06 PM
Bent wheel? Do you have a wheel/tire you can swap in to test?
Old Mar 18, 2022 | 10:31 PM
lexo98's Avatar
lexo98
Missing a lot of details. Was the tire repaired, how was it repaired? Who repaired? Is the spare on?
Old Mar 20, 2022 | 05:55 PM
Frankn's Avatar
Frankn
Well i didnt have the right size spare so i had to put two different sizes wheels on the front and back. Low profile wheels in the front and RX300 wheels in the rear since i had them around. Ive driven on both sets of these wheels separately and they were ok except i know that one tire out of the set of low profiles does have a shake, i dont think i put it on because i dont feel the wheel shaking or anything.
Tire pressures are ok. Completely rust free car pretty much
I do have other wheels to swap in but i dont have a complete set of the same ones to test. I take it this will be the first step.
I do my own repairs unless things get out of hand. I have been in the car game for a while, mainly turbo Nissan stuff, building motors and burning EEProm chips (haha who remembers that) but new to this platform. I can service it but im no pro with diagnosing suspension issues
Thank you guys
Old Mar 24, 2022 | 09:56 PM
Frankn's Avatar
Frankn
I have a few days with a lift. Might pull the rear subframe out and see if anything looks loose
Old Mar 25, 2022 | 09:22 PM
Frankn's Avatar
Frankn
It pulls to the right when I give it gas and when I let off it goes left. Rear control arm bushings?
Anyone make a good set of polyurethane bushings for the rear of our cars?
Old Mar 25, 2022 | 11:53 PM
S2Kiwi's Avatar
S2Kiwi
Yeah sounds like bushings gone bud. Shaking though could be tyre balance is out and it's triggering the suspension slop to move enough and cause you issues. Also check shocks are not leaking/clunking.
Edit: if your shocks are like the 3gs you can't really inspect the bushing at the bottom easily without removing them. You can see the sag of the bolt through centre line of where you'd expect the shock rubber to be sitting.
Old Mar 26, 2022 | 08:52 PM
Frankn's Avatar
Frankn
this bushing is loose in the rear. Rear control arm?
Thanks
Old Mar 26, 2022 | 09:11 PM
firelizard's Avatar
firelizard
https://www.clublexus.com/forums/sus...placement.html
Old Mar 27, 2022 | 10:15 AM
natman's Avatar
natman
So the wobble started after you changed wheels, including one wheel that has a history of problems. Odds are excellent that the new wheels are the cause. It's unlikely that the rear subframe developed a problem at the same time, unless there's more you haven't told us.
Get the flat fixed, put the original wheels on and see if the problem continues.
Old Mar 28, 2022 | 05:56 PM
Frankn's Avatar
Frankn
In process
Old Mar 28, 2022 | 09:08 PM
Frankn's Avatar
Frankn
I changed out the spherical bushing thing. Still wobbly but it was obviously bad so that's OK.
I'm getting some wheels lined up. Already got 2 stock wheels and just need a few more good ones at a junkyard.
I have to leave the project for a while and come back to it in a month or so. I should have good wheels and tires by then as a starting point.
Old Mar 28, 2022 | 10:24 PM
S2Kiwi's Avatar
S2Kiwi
that bushing was shot, it'll also lower your car and cause alignment to be out, so good fix man nice work. At this point I think wheel balance/wheels now you've got any offending rubber out the way.
edit: there is no play when wheel mounted back normally eh? e.g. you cant shake/wiggle/clunk it side to side?
Old Mar 29, 2022 | 11:37 AM
lexo98's Avatar
lexo98
Are you using Toyota/ Lexus lugnuts on stock Toyota/Lexus wheels and regular lugnuts on aftermarket wheels?
Old Mar 29, 2022 | 11:39 AM
Frankn's Avatar
Frankn
Yes..... for now til I get the other tires on there...?
Flash5
Oct 20, 2018 10:43 AM
rominl
Suspension and Brakes
313
Jan 18, 2017 08:25 PM
ipwn
Mar 5, 2013 12:47 PM
TechGreek
Oct 26, 2010 09:53 PM
VJ RC51
Feb 6, 2006 03:49 PM
