Code p0400
Old Mar 4, 2022 | 01:18 PM
Dan300's Avatar
Dan300
Default Code p0400
My check engine light came on the other day. I use my code reader and p0400 pop up which is a evap leak. Has anyone had this problem and what are usual fixes for this code ?
Old Mar 4, 2022 | 04:14 PM
TrueGS300's Avatar
TrueGS300
What is your year and model? P0400 is a generic EGR code which the GS300 and I'm pretty sure 400/430 don't have. Are you sure it wasn't P0440 or 442? Some numbers after the 04? Those would be EVAP. Either way, it's probably sensing a leak in the fuel tank/canister and lines system which you will likely need to pay a shop to diagnose. But check your gas cap for a good fit and no cracks or a flat rubber seal. Replace if the cap is bad and clear the code and see if it comes back.
Old Mar 4, 2022 | 07:10 PM
Dan300's Avatar
Dan300
I have a 01 gs300 . Yes the code was p0440 i made a mistake. I will replace gas cap and clear code and see if that fixes the check engine light before I take it to be diagnose. Thanks for the information
Old May 9, 2025 | 12:44 PM
mrspankaho3's Avatar
mrspankaho3
1st Gear
Default Lexus gs300 01’ code p0440
HOPE THIS HELPS!
dadewi
GS - 1st Gen (1993-1997)
12
Oct 22, 2018 12:45 PM
rmk9785e
RX - 1st Gen (1999-2003)
Oct 5, 2017 09:46 AM
hms09
Aug 20, 2013 06:25 AM
strad
Jun 5, 2010 04:36 PM
mrpitbull
Dec 31, 2004 10:05 AM
