Timing belt slack
Old May 6, 2025 | 04:00 AM
Hooky's Avatar
Hooky
2nd gear
Post Timing belt slack
Hi guys, I have 2003 GS 300, 2JZ-GE VVT-i, I'am worried if my timing belt is too loose. Could you take a look and tell if that's normal? I attach video.
Thanks in advance.
File Type: mov
Old May 8, 2025 | 11:31 AM
Answer300's Avatar
Answer300
Thanks in advance.
Honestly that’s not too bad. When was the last time you had it replaced? The bigger indicator would be if you see visible stress cracks in it along with fray marks
Old May 8, 2025 | 10:46 PM
Hooky's Avatar
Hooky
2nd gear
Last replace was done around 10k miles ago, but not 100% sure, because it was done by previous owner. I believe he did, because water pump and belt tensioner looks like new, also no leaks from gears. The belt itself looks like brand new.
Old May 10, 2025 | 06:55 PM
Answer300's Avatar
Answer300
I think it’s fine. It’ll be extra tight on a fresh install but with the tensioner in place you should be good. Honestly, you can see if there is some thread to be tightened up on tensioner too. Just because it’s installed and pin pulled to create tightness doesn’t mean it’s pushed up all the way. Some installers fear over tightening and leave a little pressure off it. You wanna make sure it’s tq to spec
DarthNater
Oct 5, 2022 05:53 PM
my2jz
May 7, 2010 10:42 AM
sillyboi12
Jan 11, 2010 06:57 PM
cadynlx
Maintenance
Dec 4, 2008 05:47 AM
ckasper
20
Jun 8, 2008 08:27 AM
