Should I change these
Old Dec 25, 2021 | 01:44 PM
QLex300's Avatar
QLex300
Default Should I change these
The hoses that connect to the airbox and PVC valve are stiff and seem old and hard is this normal?
Should I change them?
Thanks
Old Dec 25, 2021 | 02:25 PM
TrueGS300's Avatar
TrueGS300
Unless they are broken, no. But if you remove them for some kind of maintenance and they crack or break.. yes.
Old Dec 25, 2021 | 02:56 PM
CurlyG's Avatar
CurlyG
When I bought my '00 GS400 at ~144k miles, it came with several system issues, including a P0440 (Powertrain Evaporative Emissions Control System). In searching for, and solving the emissions system leak problem, I replaced many/most of the evap (and intake, different problem) lines. Many of the rubber lines were aged to a state of hard/brittleness, and some only had tiny tears/cracks near the nipple (leaks) that were impossible to spot without investigating.
When I went to pull the PVC connector from the valve cover, it was rock hard. The connector broke into several pieces, which then fell onto the valve train, which I had to pick out using an assortment of grabbing tools.
I found it very satisfying (and inexpensive) to purposely fail and remove many of these tubes/connectors at once, in my garage, and replace them with soft, fresh tubes/parts; rather than to have them fail on their own, down the road, one after another, in the middle of nowhere, mile after mile.
Old Dec 26, 2021 | 03:25 AM
QLex300's Avatar
QLex300
Hi
Thanks for the info
Old Dec 26, 2021 | 03:26 AM
QLex300's Avatar
QLex300
Thanks for sharing that info
Old Dec 26, 2021 | 02:12 PM
CurlyG's Avatar
CurlyG
Sure thing! Post again if you have any more questions
Old Dec 27, 2021 | 03:23 PM
QLex300's Avatar
QLex300
[QUOTE=CurlyG;11189979]Sure thing! Post again if you have any more questions [/QU
Hi
you post some really GREAT information and I APPRECATE that!
gs350fan
May 19, 2022 07:35 AM
badboylex
RC F (2015-present)
24
Sep 10, 2021 07:49 PM
PDengler
RC - 1st Gen (2015-present)
13
Sep 9, 2021 10:04 AM
ZaxF
IS F (2008-2014)
Feb 8, 2015 10:06 AM
