Help with finding eshift retrofit
Hey guys been search the forum for the how to retrofit eshift steering wheels but I only find other tread of people asking how to do it and the reply’s are just people opinions of the function and so on, no actual how it’s done. Been told it’s one wire. I have Aristo swap and the TRD M cluster, M mode shifter and the eshift wheel and Aristo ecu. Can someone link me to the how to please?.
It's pretty straight forward. What specifically are you looking for help with? I'm assuming you know how to get the steering wheel off. As far as the eshift, you run a wire from SFTU and SFTD (as I recall - double check the ECU diagrams) pins at the ECU to the back of the clockspring at the steering column. That's basically it. All you have to do to active the shift up or shift down function (assuming your transmission is in e-shift mode) is ground either of those wires - that's what your buttons effectively do on the steering wheel when you press them. If you have any more specific questions, give a shout. It's been a couple years since I did it, but I don't remember there being any difficulties with it.
I assume you allready have this link allready:
https://www.clublexus.com/forums/per...-your-gs3.html
AeroSS87
Mar 15, 2018 08:27 PM
