Aftermarket LED Tail Lights
Recently got rear ended and as such had to get new tail lights. I originally had these aftermarket "smoked" tail lights and they worked fine so I ordered the same ones.
The tail lights and brake light are both LED** I only had to replace the driver's side. When I replaced the housing and was connecting everything, the brake light doesn't work (passenger side, trunk & rear window all work) The tail light does (tail light meaning when you turn the headlights on). I checked the fuse but it hadn't blown. Any possible solutions?
2. If yes...does the brake light still work when you connect them back?
hawk362
Nov 23, 2009 01:42 PM
