Code p1120
Old Nov 9, 2020 | 12:32 AM
Vicflo845's Avatar
Vicflo845
Default Code p1120
Car bogs out then shuts off. But I have to step on the gas pedal to the metal to accelerate?
Old Nov 9, 2020 | 03:48 AM
TrueGS300's Avatar
TrueGS300
You just had repairs done to the wiring on your car right? Do you know where the repairs were made? They may have messsed up the connection for the APP sensor at the throttle if it was removed. Look for a damaged connector or wiring. It’s the sensor on the firewall side of the throttle body where the cable connects to.
Old Nov 9, 2020 | 09:41 AM
Vicflo845's Avatar
Vicflo845
Wires and connections look good
Old Nov 10, 2020 | 01:58 PM
KyleH's Avatar
KyleH
The error code is related to your pedal position sensor. The fact that your car only revs/goes when you mash the pedal all the way down is indicative that the TPS is not getting signal from the pedal position sensor and only moving when the last 10% of pedal travel activates the physical cable attached to the throttle linkage. Since you also have the ECU telling you that the pedal sensor is at fault, focus on that area.
Old Dec 5, 2020 | 05:23 AM
Yamae's Avatar
Yamae
I recently had a P1120 problem on my 98 Celsior which is quite similar to a LS400. It was caused by a failed APPS but it was fixed just resoldering the cracked soldering points. You can find more here. Two links there are in Japanese though.
SUNLINE
LFA Model (2012)
Nov 10, 2020 06:12 PM
Oct 29, 2020 05:29 PM
hms09
Aug 20, 2013 06:25 AM
mrpitbull
Dec 31, 2004 10:05 AM
