Code p1300 & p0715
Old Nov 7, 2020 | 07:21 PM
Vicflo845's Avatar
Vicflo845
Default Code p1300 & p0715
Car runs perfect then code appeared parked it then it shut off instantly. I replaced the igniter already
Old Nov 8, 2020 | 06:19 AM
TrueGS300's Avatar
TrueGS300
The usual issue with the igniter code seems to be old brittle wiring and connectors going through the valley to the coils. Sometimes it's a loose connection do to broken a connector(s), wires that have cracked and are able to touch each other or the engine, corrosion or fluid from leaks entering wiring/connectors. Many possibilities as these engine's are aging. But the P0715 code is bad news for the transmission I'm afraid. I'd have a real diagnosis done from a transmission specialist shop, otherwise throw an input shaft speed sensor at it and hope for the best. My experience is that you will need a new trans with that code.
Old Nov 9, 2020 | 12:34 AM
Vicflo845's Avatar
Vicflo845
Thanks bro, I got it fixed it was bad wire connection & cracked wire
Vicflo845
GS - 1st Gen (1993-1997)
Dec 28, 2021 10:11 PM
flex5150
Nov 14, 2020 07:25 PM
RockAuto
Club Lexus Vendor Marketplace
Feb 12, 2020 11:14 AM
