Manual swap
Old Sep 16, 2020 | 08:29 AM
cromer's Avatar
cromer
Default Manual swap
I’m trying to find the best stock manual tranny to put into a 2003 gs300
Old Sep 16, 2020 | 12:03 PM
firelizard's Avatar
firelizard
Cd009
r154
w58
Old Sep 17, 2020 | 06:05 AM
TrueGS300's Avatar
TrueGS300
There are a lot of things to consider. You need to know your power goals and intended use. If you just want a manual trans to cruise around in, a w58 is a good cheap option, but wont hold much power. The r154 can hold more supposedly if you are thinking about power adders, but they seem to get blown often at even 300whp power levels talking to the guys on Supraforums. The Cd009 is a popular 6 speed choice, relatively strong, but an expensive route due to the adapters and cost of everything. Arguably the best transmissions are the T56 magnum or newer TR6060 if you are going for big power or racing, this very expensive but may be necessary if you have big power goals. There is also the V160 from the Supra TT, but they are outrageously priced and hard to find discontinued parts for.
Anyways, whats "best" can be very different depending on your needs.
Here's a discussion on the strength of these two: https://www.clublexus.com/forums/per...8-vs-r154.html
Some info on why a T56 is good: https://www.grannasracing.com/blogs/...v160-and-cd009
YoYi
Jun 29, 2020 07:04 AM
Kaen13
Apr 29, 2019 08:46 AM
theory5150
Apr 30, 2009 02:19 PM
rembo
Jul 15, 2007 11:07 PM
00'Si-in-red
Performance
Nov 26, 2001 09:57 AM
