Lost Key :(
Old Nov 22, 2019 | 05:58 PM
Alphaman19's Avatar
Alphaman19
Default Lost Key :(
Wondering if the Ecu can be reprogrammed.
I here things both ways but not sure.
Looking on eBay for a Ecu and key.
Any suggestions?
It was the only key I had.
Could be worse.
Thanks
Old Nov 22, 2019 | 07:13 PM
kevin3344's Avatar
kevin3344
Yes, do a search on eBay for "lexus ecu reflash" or something like that. There are several services that will reflash your ecu and send you a new key. For example:
Old Nov 29, 2019 | 12:26 PM
sbagdon's Avatar
sbagdon
To clarify... believe the '98-'00 has to be re-flashed back to factory, then you add keys like it just came off the end of the line. There's no way to wipe or replace codes in the ECM, it has to go back to factory.
Believe '01+ went away from this limitation.
Old Nov 29, 2019 | 01:09 PM
Alphaman19's Avatar
Alphaman19
Found a service on eBay where I sent my Ecu and they’ll give me back two keys with the programmed rfid chip inside. It’s in the mail back to me so I’ll let everyone know how it goes when I get it Tuesday.
Fingers crossed.
Old Dec 4, 2019 | 04:43 PM
Alphaman19's Avatar
Alphaman19
Got the ECU and keys back today. Dropped it in and vroom! Now I’ve got two keys. Not bad for roughly $200. I highly recommend the services in the attached photo.
Old Dec 4, 2019 | 05:05 PM
kevin3344's Avatar
kevin3344
Glad we could be of help!
Old Dec 4, 2019 | 05:51 PM
Crispins's Avatar
Crispins
Could you post an actual link to those keys and programming service, I would love to have better keys for my car.
Old Dec 4, 2019 | 07:48 PM
shwalker07's Avatar
shwalker07
This happened to me too. I bought a new master key from my local Lexus dealer for $141 and I brought in my car title and ID so they can cut it for free to the vin.
Once that new key was cut I took out the ecu and mailed it in to a ECU reprogram service on ebay with the new master key that the Lexus dealer cut so they have a reference since it also included two cut valet keys. I been fine for about 2 years since this happened but I spent a bit under $500 for everything at $141 a piece for 2 new cut master keys and about $185 for the ecu reprogram service (it is cheaper now).
Also you will need to program the master key yourself for the unlock/lock trunk buttons to work. Those instructions are on here and very easy to do.
EDIT: Just saw you got everything working again, glad everything worked out for you.
Old Dec 5, 2019 | 10:46 AM
GS300freak's Avatar
GS300freak
Fingers crossed.
Maybe a stupid question, but can't people just break into my car, replace the ECU and start and move the car then? Because if I'm correct, the alarm turns off after it has been on for a few seconds...
Old Dec 5, 2019 | 10:53 AM
Tank's Avatar
Tank
Luxious Automotive has better looking keys.
jehmin
Nov 7, 2023 12:12 AM
dadoo
19
Jun 30, 2018 09:41 PM
Kadrian87
Sep 22, 2016 04:24 PM
Dadikins
RX - 1st Gen (1999-2003)
Nov 16, 2010 07:05 AM
