Planning out a new stereo system...
Of course it's a solid car. That goes without saying.
Though going on about the system, I feel like I'm wasting my time because it seems that the entire concept is beyond the scope of some here...
My summer project: I'm looking at retiring my 10" Kicker Comp C in the stock location for a pair or 12s or 15s IB setup. Your planning is sound. I'm looking at building a "5 sided box" that will be angled like you described. I want to fire through the rear seat, and seal, dampen, and reinforce the package tray. The stock location for the 10 is fun, but a complete rattle trap.
I'll follow your build and am happy to share what I get going.
ChopsGS (06-19-19)
Not everyone.
Oddly, the GS400 comes with a 10" sub, the larger LS430 comes with an 8" sub. I guess because it may be a quieter car on the inside and Lexus felt it didn't need such a big sub?
I've been following this because I still have yet to do any stereo system changes. At least the idea is still note-worthy. I think I'm just going to swap in a 12" in place of the factory 10" and use my own amp (remove stock and maybe install it there) with a touchscreen deck (kenwood or Pioneer) Upgrade the speakers later. Trying to keep weight down since I'm going for performance in it too. I pulled out the CD changer already because it is obsolete with Bluetooth technology and all. The thing weights at least 30 lbs. I like stealth, so any factory spots I can use I will. Any thread I read about this stuff helps me out because this is definitely not my area of expertise.
ChopsGS (06-20-19)
You'll need to cut a fair bit of cutting of the rear deck to get a 12" sub to work in the factory location. I would suggest you just get a 10" to make your life easier. I used an Alpine MV500 mounted to the bottom of the rear deck and used the line level in from the factory sub woofer to get a signal and used an Alpine SWS-10D2 in the factory location. I wanted to keep my factory ML speakers and head unit though. Its worked well for me so far but something that I saw in the GX forum is that when using that make sure the line level voltage doesn't go above 10V as thats what aftermarket amps are rated for. Someone recommended using an LC2i to control the input if the voltage is too high
Jtc016
03-19-17 01:22 PM
vondy21
29
05-28-03 03:02 PM
