Gs 430 oil pan leak.
Anyone ever get and repair there oil pan leak.
Mine is leaking under the k member so those are the couple of 10mm I cant reach.
I'm guessing I will unbolt both motor mounts and cherry pick the motor and hopefully have enough room to get the pan out and reapply gasket maker.
Any one else do this ?
That is about right, those last few 10mm bolts are tucked up there. You will have to either raise the engine a bit or drop the cross member.
Mine is not leaking yet and I am not looking forward to doing that job.
Check over on the LS section I think I saw a post there where a member posted some steps/tips.
I thought as much. I've changed the motor mounts so I know that motor can go up but not very high ! But it is the easiest way .
Thanks guys for getting back to me.
starfyrels
09-26-11 05:52 PM
