LED light bar install
Old Nov 17, 2018 | 11:05 AM
CochyGS's Avatar
CochyGS
Default LED light bar install
I can't seem to find anything specifically for the 2GS on this. I'm installing a light bar in the front lower grill area. Where is the best place to run the switch wires through the fire wall? It looks like there is a boot right behind the battery I could use but will I have to remove the dash to get it to the driver side (LHD car)? That's the only thing holding me up right now
Old Nov 17, 2018 | 11:56 PM
shwalker07's Avatar
shwalker07
Usually if you remove the front plastic wheel well cover you should see a rubber boot that runs body wiring into the cabin. This is where I always go on my projects that need power or wiring so it keeps it hidden and looking clean as well.
Old Nov 18, 2018 | 12:45 AM
TW99GS300's Avatar
TW99GS300
There's no need to remove the dash, a tip I learned years ago from a stereo installer friend of mine was to use something flexible like 2 feet long zip ties, tape the wires to the zip tie, pry the edge or cut a slit on the boot and poke the ziptie thru. There is one boot on the passenger side and 2 on the driver side, I am currently running an Infinity standalone harness thru the driver side and 00 gauge wiring on the passenger side like this.
Old Nov 18, 2018 | 11:46 AM
CochyGS's Avatar
CochyGS
Is the boot in the firewall on the driver or passenger side?
Old Nov 19, 2018 | 01:58 AM
TW99GS300's Avatar
TW99GS300
There is one right behind the battery and there is two by the side of the Brake booster.
Old Nov 19, 2018 | 03:34 PM
CochyGS's Avatar
CochyGS
thank you. I'll try the brake booster side first. Your all rule
ISTexas
Jun 6, 2017 08:35 AM
sparta3993
Aug 18, 2016 11:34 AM
tresmith00
NX - 1st Gen (2015-2021)
14
May 27, 2016 09:14 PM
BlackDog59
Lighting
Oct 23, 2013 08:21 AM
andboom
Lighting
Oct 4, 2010 01:33 PM
