Need help identifying engine knocking
Old Apr 11, 2018 | 03:41 PM
Letsride's Avatar
Letsride
Some side to side play is acceptable but that seems excessive. Can you possibly try to move the caps up and down? That will simulate the motion of the rod and give you a better idea of the play on those rod journals.
Old Apr 11, 2018 | 03:42 PM
Letsride's Avatar
Letsride
Whats the condition of the lower pan? Any buildup?
Old Apr 11, 2018 | 04:34 PM
BrenYF's Avatar
BrenYF
There was actually a small amount of sludge in the oil pan, (bit less than a handful). Did not see any metal shavings or big pieces. I can get a picture tomorrow, too dark right now and I forgot to take pictures. Makes me think that the sludge buildup probably messed with lubrication.
Old Apr 11, 2018 | 05:01 PM
Letsride's Avatar
Letsride
When you check the pan tomorrow use a magnet and see if any particles in the sludge stick to it......
Old Apr 11, 2018 | 05:05 PM
BrenYF's Avatar
BrenYF
I actually dragged a magnet through and there weren't any noticeable particles sticking to it. Nothing shining in the light as well. Other than the sludge, the oil looks ok.
Old Apr 19, 2018 | 11:20 PM
BigTurtle's Avatar
BigTurtle
is the noise coming from the top of the engine ? sounds like a stuck lifter, i installed a jdm motor into my GS and has a knocking sound similar to yours i threw in some Rislone Engine Treatment Concentrate 16.9 oz and cheap oil and drove it for 30 miles knock noise gone
Old Apr 24, 2018 | 05:14 PM
BrenYF's Avatar
BrenYF
Too late to tell now, already pulled the motor since I was planning on a GTE swap haha
Old Apr 25, 2018 | 01:00 PM
lextout's Avatar
lextout
i would never buy a car that had engine rebuilds, but again thats just me.
Old Apr 25, 2018 | 04:30 PM
BrenYF's Avatar
BrenYF
Yeah I didn't really pay attention when I bought it, even looking in the oil cap you can see a small amount of dark sludge. I wanted to swap it down the road anyway since its a '99, didn't expect it to happen so soon though! Oh well, time to make it better.
Old Apr 25, 2018 | 06:16 PM
burteboy's Avatar
burteboy
I listen to your video u have a serious problem its a rod noise maybe #2 or #3. Iwould stop driving the car at this time and get it repair asap. Ance you get a good guy they can rebuild that engine to run like new. Hopefully the crank is not damage.
Old Apr 25, 2018 | 06:20 PM
Letsride's Avatar
Letsride
Old Apr 27, 2018 | 12:06 AM
BigTurtle's Avatar
BigTurtle
i wanted to swap a 98 but 2 years from now, unfortunately previous owner botched the cooling system and blew a head gasket, couldnt afford a gte ended up getting a jdm GE in there.
Old Apr 27, 2018 | 04:11 PM
BrenYF's Avatar
BrenYF
That's a bummer. Luckily my GE had a pretty new water pump, ps pump, timing belt tensioner, belts, radiator and only 127k miles on the chassis. Will save some money swapping the parts over.
GSCarlitos
Mar 27, 2019 06:51 AM
Mrfouche
Aug 1, 2017 02:28 PM
computerwi
NX - 1st Gen (2015-2021)
17
May 3, 2017 11:55 AM
Lawgs300
Dec 4, 2010 09:56 AM
sc300tilt
Jun 18, 2010 02:36 PM
