turned off while sudden braking
Old Mar 26, 2018 | 06:48 AM
tyson rust's Avatar
tyson rust
Default turned off while sudden braking
i have a 2001 gs300 252k miles I was driving about 50-60mph and made a sudden stop at the light once I did the car completely turned off. all lights came on, I put car back in gear and it started back up no problem, has anyone experienced this? if so what could be the problem? currently the VSC LIGHT HAS BEEN ON also THE CHECK ENGINE LIGHT HAS BEEN ON. [ need solenoid installed] just haven't had it installed yet.
Old Mar 27, 2018 | 12:02 AM
shwalker07's Avatar
shwalker07
You have tons of solenoids on the vehicle (Starter solenoid, vtti solenoid, transmission solenoids, ext....), what solenoid are you referring to and what are your engine codes?
Old Mar 27, 2018 | 09:27 AM
kevin3344's Avatar
kevin3344
Check and see if you have any loose or cracked vacuum hoses. This would happen to me about once a month after the car warmed up. It would either stall or the RPMs would get very low like it was about to shut off. It would always start right back up. Keep in mind I have a GS400 though so not sure if it’s the same issue.
Old Mar 27, 2018 | 02:23 PM
tyson rust's Avatar
tyson rust
its the vacuum switch valve i can't remember the code but that what it was i just haven't had the vacuum valve installed yet its connected to the charcoal filter for sure
Old Mar 27, 2018 | 02:25 PM
tyson rust's Avatar
tyson rust
ok i will do that i did remember the mech saying that there were cracked hoses ill double check that they were replaced thanks
Old Mar 29, 2018 | 03:29 AM
Askur44's Avatar
Askur44
I have this issue as well. Let me know what ended up happening.
Old Mar 29, 2018 | 04:28 PM
Kain52's Avatar
Kain52
Similar to mine road issue half a year ago.
While driving car started shutting down on road bumps. Most of the time for a half a second, so the engine was still running, but sometimes for a couple seconds, so I had to move off the road, put the car on "P" and then start it again. Same lights were on. Back then I just bought it from used dealer.
Next day, I checked the engine and in my case the issue was wires from after-market equipment removed by the previous owner. Maybe alarm, maybe custom horns, which was most likely the thing. So one of the wires was connected to the Positive terminal of the battery and after going in the front somewhere underneath in the front. I just pulled that crap out, there were couple relays rusted wires and it wasn't connected to anything besides my battery. So on the bumps those wires were hitting the body of the car basically shortcutting itself knowing that its plugged to the "+". Got it out - drove 30k miles after - no issues.
So seems like its a shortcut. My guess would be to start with Checking the terminals on the battery. How tight, condition... Good luck
Dtur15
Jan 5, 2016 04:46 PM
mbrown1782
Feb 26, 2013 07:53 PM
ezpickenz
Feb 16, 2010 05:20 PM
redstar142
GS - 1st Gen (1993-1997)
12
Nov 23, 2004 08:01 AM
17gs400
Jan 23, 2004 07:19 AM
