2JZ-GTE JZS161 cable near map sensor?
Old Mar 29, 2018 | 11:09 AM
ekuskun's Avatar
ekuskun
Default 2JZ-GTE JZS161 cable near map sensor?
Hello,
My engine was making making strange noise during idle ( something like blop blop blop ) I was checking almost anything to understand what causes it,
then I found a cable near map sensor on inlet manifold (attached the photo )
when I remove it, noise disappears
I don't know what does it actually do, but it sounds like breathing ( like an air solenoid )
can somebody please tell me what is that for ? and why can it cause noise.
I attached a photo, thank you.
Old Mar 29, 2018 | 01:31 PM
Letsride's Avatar
Letsride
Are you removing the connector from the VSV and the noise goes away?
Old Mar 29, 2018 | 02:07 PM
ekuskun's Avatar
ekuskun
Yes, When I Remove the connector, noise goes away
Old Mar 29, 2018 | 02:34 PM
Letsride's Avatar
Letsride
Check that VSV and hoses for cracks. If none are visable you have a bad VSV....replace it.
Old Mar 29, 2018 | 04:49 PM
badblackgs's Avatar
badblackgs
thats the evap purge solenoid. i know its crazy that its not even used. its not hooked up to anything. it just loops back on itself. but i know for a fact that its the evap purge valve because ive hooked the scan tool up before and commanded it on and off and made sure. just weird that its there but serves no function.
mann777
GX - 1st Gen (2003-2009)
Oct 12, 2010 08:33 AM
hmkim
Mar 22, 2006 02:56 PM
Static911
Feb 1, 2002 03:09 AM
