help about VSC AND PWR and abs
So as i got my gs400 2000 and it has 180k on it and the vsc and pwr and snow buttons are not working also the abs was bad so i changed it but neither an abs or vsc or pwr comes on when i put the car on igintion and when i start it the buttons do nothing so any help ? any fuses to check? really i cant drive the car in rain
So none of the lights come on when you press the buttons or the warning lights illuminate on the dash? Not sure if this is your problem but a quick google of "vsc zero point calibration" and see if that's what you're needing to do.
YES NONE of the lights illuminate on the dash and nothing happens when i press the buttons about the zero point i will try that but i need to know if they are even functionally working or no
Are you the original owner or did you purchase this car from someone? Meaning have you seen them illuminate before? Reason I say this is because I have seen cars that have had this issue and really what I found out through process of elimination is that the previous owner couldn't figure out why the lights wouldn't go off in the cluster so they pull it out and remove the bulbs on those indicators. Sounds silly but it happens.
I bought it from a person but the speedometer was broken so i changed it so maybe he could disable the system? any way to get it back? as the all the lights work except the vsc and abs and ect as the abs was malfunction so any suggs?
Also, what do you mean by the "ABS was bad so you replaced it"? What did you replace?
mikevanle
01-30-15 03:43 AM
