Can't get my VSC/ABS back to work!
Hi everyone,
A couple of months ago I unplugged my ABS/VSC cable under the hood. I did this because one of my ABS sensors died, because of this the ABS was kicking in at every stop, so I just wanted to get a rid of it since it was annoying. By this time there were no lights at the dash. When I unplugged the cable, the VSC/ABS/VSC OFF lights came on (it's supposed to do this).
Now it's snowing out here and I want to get my VSC back to work...so I just plugged the cable back in and guess what...VSC/ABS/VSC OFF lights are still on. I've searched and found that you had to press the brakes about 5 times to activate it, doesn't work either! How is this possible? Everything worked before I plugged the cable out (ABS kicking in was annoying only), what can this be? I'm stressing because I'm thinking I messed everything up now.
Am I doing something wrong by activating the ABS/VSC? Please help!!
Thanks a lot.
Regards,
GS300freak
Thanks a lot.
Regards,
GS300freak
can you please tell me where is this cable cause i bought an gs400 that abs was malfunction and the first owner disconnected the vsc abs and now i replaced the abs and i need to plug it back any help tho?
TonY_G
07-28-07 12:47 PM
