Help about instrument cluster gs400
So my speed needle wasnt working and my temp gauge and nothing of the dashlights was working so ibought a 02 Gs300 and its working perfectly main problem that the E shift screen is gone and the airbag and headlight leveling is on and i cant disable vsc or even Pwr they are not up on the dash so can i fix my old speedometer with the new one and put the old one on again?
When dealing with anything electrical you always want to start with a solid battery; volts should be a little over 12v at rest. Next, be sure your fuses are good. Some have had good results resetting the ECU. That is, disconnect the negative battery cable for about 45 min and then reconnect.
If you disconnected the battery, checked fuses, etc. you will need to take to Lexus to diagnose. Cost will be about $140 but it's better than guessing as to what the problem might be.
tmf2004
09-09-13 09:09 AM
skpark70
SC- 1st Gen (1992-2000)
10-30-07 06:48 PM
