There are no sensor wires. Pretty basic brake set up. If you haven't replaced the hardware kit lately (clips, springs, etc..) I would also do that. Make sure the slide pins are lubed and don't stick. Oh and turn the rotors or replace them if needed
I cant think of anything you would need to replace other than pads. But if you're that **** about wanting to replace everything, here are the 2 kits you need:
i only replaced the hardware on mine a few weeks go since some were missing but only because I'm ****. I've driven many cars missing most of that gear and it was fine.
But seriously, I see no reason to HAVE to replace them. I'm missing almost half the pieces of both kits LoL Everything works just fine
I usually don't replace hardware on any other car I've done brakes on, but with all the popping noises I was getting and sticking slide pins it made a difference. Also I used oem pads but bought the hardware kit from oriellys. Used their brand and it appears identical to oem
