Need Help
Old Jun 11, 2017 | 11:29 AM
Corey513's Avatar
Corey513
Default Need Help
My 2001 gs300 won't start because i hooked up the battery wrong and the alarm system started to go off so i hooked it up the right way and it still doesn't start i checked the fuses i blew some replaced them. But my fuel pump won't engage and my dash board won't light up. I'm really unsure of what to do now. it cranks but want start
Old Jun 11, 2017 | 07:12 PM
burteboy's Avatar
burteboy
Did you check your main fuse. There is a fuse am2 check that. How are you checking your fuses , hope you are using a dvom or a tester light .
Old Jun 12, 2017 | 07:15 AM
BiGEZ's Avatar
BiGEZ
You still have some blown fuses to replace. Look at your fuse boxes and check them one by one using a DVM of lest light as mention above. The diagrams for the fuses are printed inside the covers.
Old Jun 13, 2017 | 12:37 PM
Corey513's Avatar
Corey513
Thank you guys i really appreciate it your help
Old Jun 14, 2017 | 01:49 PM
Corey513's Avatar
Corey513
I don't have a doom but i do have a test light
Old Jun 19, 2017 | 05:26 PM
burteboy's Avatar
burteboy
Default no start
Check your 5amp ign fuse, 25 amp efi fuse. The ign fuse would cause dash not to light up and the efi fuse power up your fuel pump.
jazzzman
NX - 1st Gen (2015-2021)
May 1, 2023 10:01 AM
2JZwannabe
Apr 29, 2012 09:39 AM
mak89
May 8, 2011 03:38 PM
LasVegasGS
Feb 21, 2005 12:01 AM
