Dimming Gauge Cluster Lights
Old May 19, 2017 | 10:17 AM
Louielace6's Avatar
Louielace6
Default Dimming Gauge Cluster Lights
At night when I'm driving they appear brighter when I give the car gas
Could my alternator be on its way out?
Thanks Everyone
Old May 20, 2017 | 02:14 PM
bruceb58's Avatar
bruceb58
Have you measured the battery voltage with a meter?
Old May 22, 2017 | 03:18 PM
BiGEZ's Avatar
BiGEZ
Get your battery and alternator checked out, seems you charging system is not up to snuff. That is a sign either you battery or alt is going out.
Old Jan 21, 2024 | 12:16 PM
Louielace6's Avatar
Louielace6
After fiddling around on top of my dash & covering up the ambient light sensor, I’ve come to the conclusion that this is my culprit
It’s red in color instead of black like the one on the passenger side
Sometimes my light switch will not adjust the dash lights & if I cover then uncover the sensor with a rag or so my gauges will automatically stop illuminating
has anyone ever replaced the ambient light sensor & how difficult of a job is it?
Thanks Everyone
ryone
Old Jan 21, 2024 | 12:26 PM
naluloa's Avatar
naluloa
Is that the little red bump thingy near to where the windshield meets the dash? I haven’t changed it but I was looking at it today when I got home
Old Jan 21, 2024 | 01:33 PM
Louielace6's Avatar
Louielace6
Yes that’s the one
i was wondering if it was red or black originally but I think it’s bad
Old Jan 21, 2024 | 03:38 PM
naluloa's Avatar
naluloa
Oh cool when I was looking at it I thought it was for sensing if the windshield broke or not. Mine has been red for the last 20k miles and I haven’t had any dimming issues so as far as I can tell red is normal.
Old Jan 22, 2024 | 09:01 AM
McPierson's Avatar
McPierson
Thanks Everyone
ryone
My 02 dash sensor has a red color.
Here’s how mine works.
When the sensor says(day) The dash back light does not dim at all. If I turn it down far enough it will turn totally off.
When the sensor says (dark) The dash will adjust up and down with the ****.
It’s possible to adjust the dash at night to a very low level, then Get in day time and think the dash has broken when it’s just adjusted low.
hope that helps.
Old Jan 22, 2024 | 09:49 AM
Louielace6's Avatar
Louielace6
Mines will completely shut off when I turn the brightness all the way up on a bright sunny day
Old Feb 26, 2025 | 04:36 AM
Louielace6's Avatar
Louielace6
I recently replaced my rheostat **** to no avail as my gauges still have the same issue
Has anyone replaced the sensor on the driver side of the dash & is it a ***** to do?
Also it is red & the passenger sensor is black
should they both be black?
Thanks Everyone
Old Feb 28, 2025 | 07:01 AM
dwoods801's Avatar
dwoods801
Your gauges sure look white, I wonder if someone converted it from CFC lighting to LED’s or something? That could also explain why it isn’t dimming correctly
Old Mar 2, 2025 | 08:01 AM
Louielace6's Avatar
Louielace6
I brought it off an older dude who supposedly only drove it on weekends
He said he didn’t do anything to it but routine maintenance
I'm gonna eventually pull the gauges to have a look & make sure all wires coming in are fine
akafixture
Apr 17, 2017 04:47 PM
vista4u2
Aug 8, 2016 08:31 AM
SWEETSOUND2001
Jan 11, 2002 05:23 AM
SWEETSOUND2001
Maintenance
Jan 9, 2002 09:20 AM
