Acceleration problem
Old Apr 29, 2017 | 07:23 PM
mammad13's Avatar
mammad13
Default Acceleration problem
Hi dear.
I have a 2003 Lexus GS300.
Engine hesitate for couple seconds on initial take off. (Doesn't respond immediately when I push the gas pedal)
I have already replace the TPS ,Pedal Position sensor and ECM,
.Please advise. mohammadrmoini@yahoo.com
Thank you.
Mohammad
Old Apr 29, 2017 | 07:31 PM
mate01's Avatar
mate01
clean the maf sensor and check the purge valve sensor
Old May 1, 2017 | 11:38 AM
kevin3344's Avatar
kevin3344
Look around your purge valve and see if there are any cracked vacuum hoses. Happened to me a while back.
Old May 2, 2017 | 09:12 PM
bruceb58's Avatar
bruceb58
I think you guys helped me here. Had an intermittent bog on acceleration and I found one of the clamps on the hose that comes from the vacuum valve to another fitting was moved down from the end. I had taken the hose off when working on my intake manifold and had not moved it back up. May have had a vacuum leak.
At least for today, do not have the bog.
BTC89LS400
Dec 20, 2017 03:36 AM
pon-alex
46
Aug 24, 2015 07:49 PM
calticboy
RX - 1st Gen (1999-2003)
Jul 6, 2011 06:27 AM
Pescao
Aug 28, 2009 07:02 AM
vstolyarov
Apr 5, 2007 07:06 PM
