Battery/Starter issue solved
Old Oct 11, 2016 | 12:19 PM
Garz's Avatar
Garz
Default Battery/Starter issue solved
So I really thought my starter was going to need replaced. Clicking, slow turn over, barely starting, etc. Can't be the battery, I just replaced it a year ago. Also, replaced alternator 6 months ago. Well threw a charger on it, and it was less than half charged. It was also giving me an error on the charger I have. Opened the top to check the fluids. Yep, pretty damn empty. Filled them up recharged it and haven't had any problems since. I am sure I read/heard it before; check your battery first. Regardless of how old. Way cheaper than replacing the starter.
Hope this helps someone in a similar situation.
Old Oct 12, 2016 | 06:02 PM
bruceb58's Avatar
bruceb58
Check your alternator charge voltage. If it is too high, you will have a problem with the battery boiling.
Old Oct 13, 2016 | 04:51 PM
Garz's Avatar
Garz
Will do. What is the normal output? Thanks.
Old Oct 13, 2016 | 10:36 PM
bruceb58's Avatar
bruceb58
13.5 up to 14
Old Dec 27, 2016 | 03:10 PM
Garz's Avatar
Garz
Well the starting problem persisted. Turns out the battery was faulty. Of course 2 months out of full replacement warranty. So 50% off got me a new one. No problems since. My alternator voltage is 14.2. Hopefully not to high.
semperfi
Nov 26, 2017 02:27 PM
popwar4207
Oct 1, 2013 07:13 AM
MrBruin09
Mar 30, 2011 08:53 PM
n0bodi
Oct 17, 2010 12:01 PM
RedPhoenix
Mar 30, 2008 10:52 PM
