Help High Idle!!!!
Old Oct 3, 2016 | 07:07 AM
STREETGS's Avatar
STREETGS
Default Help High Idle!!!!
i cleaned the throttle body with throttle cleaner and wiped it down ......
Now the car idles at 2000rpm.
When I put it in Drive or Reverse it drops to 1000rpm.
No check engine light on, drives fine when I'm coming to a stop the car kind of wants to keep going because it's high rpm.
What can this be?
Old Oct 3, 2016 | 10:02 AM
RRGS's Avatar
RRGS
Did you check the spark plugs and air intake? It's weird because the car is supposed to idle higher in P than it does in D. When does the car idle at 2000 RPM?
Old Oct 3, 2016 | 11:19 AM
STREETGS's Avatar
STREETGS
Yes you are right!
I wrote it wrong When I put it in Park or Neutral it idles High once in Drive or Reverse it drops to 1000
Old Oct 3, 2016 | 12:04 PM
RRGS's Avatar
RRGS
It's normal that the car idles higher in P and N than it does in R and D, but it's not supposed to be 2000 RPM and 1000 RPM. When my engine is warmed up it does around 800 RPM in P and N and around 500 RPM in R and D. Does your GS idle this high with a cold engine, or when it's warmed up?
I would check the spark plugs and the air intake as soon as possible!
Old Oct 3, 2016 | 02:21 PM
lextout's Avatar
lextout
give it a couple days, it may go back to normal.
Old Oct 3, 2016 | 02:59 PM
bruceb58's Avatar
bruceb58
How did you clean the Throttle Body? Did you remove it? You use Throttle Body Cleaner?
Did you move the TPS?
Old Oct 3, 2016 | 03:31 PM
STREETGS's Avatar
STREETGS
I did remove the throttle body cleaned it and put it back together. At first after putting everything back the idle would fluctuate up and down after a while it went away now it just has that high idle I've been driving it all day today.
Old Oct 3, 2016 | 05:15 PM
lexo98's Avatar
lexo98
Is it a gs300 or gs400. I'm gonna assume 300 since I saw you on another thread. Is the throttle cable reinstalled right? Did you move the TPS sensor? That will change idle.
Old Oct 3, 2016 | 06:16 PM
STREETGS's Avatar
STREETGS
Yes it's a 300,
No I did not move the tips sensor
Old Oct 3, 2016 | 08:21 PM
lexo98's Avatar
lexo98
Yes it's a 300,
have you disconnected the battery so that the computer will relearn with the cleaner throttle body?
Old Oct 4, 2016 | 03:30 PM
bruceb58's Avatar
bruceb58
Sounds like you have an air leak. Spray some carb cleaner around the gasket and see if that affects the idle speed.
If that doesn't work, I would get a scanner that indicates TPS settings. Just a code reader won't do this though
Boblex
RX - 1st Gen (1999-2003)
Nov 29, 2016 08:20 PM
99celsior
Oct 31, 2016 01:11 AM
hypervish
Oct 16, 2011 10:03 AM
gsCrazy
Feb 2, 2007 05:20 AM
nagasakki
Jan 21, 2005 05:09 PM
