Help
Old Aug 16, 2016 | 06:31 AM
AKGWBver2's Avatar
AKGWBver2
Default Help
Hey guys, I'm doing research and found a few sources but I want to make sure before I go start buying parts I don't need. So my passenger side is blowing extremely hot air like it's coming straight off the heater core. I did research and found out its probably my servo motor but I saw there is more than one. It blows cold air on the drivers side and in the back seat vents but extremely hot on the passenger side vents. Also, when I switch it to window defrost, the air is still blowing through the vents instead above the dash towards the windshield. Any help on what exact parts I need would be greatly appreciated. Thanks in advance guys
-Shant
Old Aug 16, 2016 | 08:19 AM
kevin3344's Avatar
kevin3344
First check your refrigerant level. My passenger side was blowing warm air and I went to Autozone and a got a can of EZ Chill R134a. Refill took about 20 minutes and it's back to blowing cold.
Old Aug 16, 2016 | 09:46 AM
AKGWBver2's Avatar
AKGWBver2
So I put in the new servo motor and it's blowing cold air out of the passenger side but it still doesn't feel like it's fully cold at 65 degrees. I feel like it's stuck around 75 degrees. Any ideas why it wouldn't be at full cold? I checked me ac levels on Sunday figuring maybe I can re charge it but it's at full charge
Old Aug 16, 2016 | 10:01 AM
coolsaber's Avatar
coolsaber
Are you eyeballing the temps or taking vent temperatures?
1) Check that ac fans up front are working.
2) Clean inlets over the coils
3) Whats the differential in pressure between the low and high side
Old Aug 16, 2016 | 05:04 PM
badblackgs's Avatar
badblackgs
you need to perform an actuator recalibration. if you don't have a scan tool to do it with, pull the hvac fuse for ten seconds than resinstall it and don't touch anything for one minute.
Old Aug 17, 2016 | 10:07 AM
sakataj's Avatar
sakataj
you dont need a scan tool or to pull the fuse
post # 35 https://www.clublexus.com/forums/gs-...ger-sides.html
also OP it sounds like your having issues like i was in post # 36 from here
https://www.clublexus.com/forums/gs-...vo-motors.html
or to sum it up are you having issues with the heat set to 75+ and its blowing in deforst mode even though its not in defrost mode? if so check out post # 141 from my DIY
Old Aug 17, 2016 | 11:43 AM
AKGWBver2's Avatar
AKGWBver2
issue fixed. I ended up just needing a recharge after replacing my servo motors. My buddies gauges weren't working properly so when I put another gauge on it, it shows I needed Freon and now my a/c is blowing ice cold. Thank you for all the help guys, always appreciated!!
Lexterr
Nov 4, 2017 11:54 AM
sung35
Jul 4, 2011 12:08 PM
GS2low4NYC
Jan 8, 2010 09:41 AM
dmcclymo
Performance
Jul 30, 2009 01:28 PM
