Boiling sound comming from dash
Old Aug 11, 2016 | 10:17 AM
Choosy's Avatar
Choosy
Default Boiling sound comming from dash
Hey guys , there is a boiling sound comming from the dash, now only when the ignition is on which is really wierd, no leaks or smells so it can't be heater core, anybody ever had the same problem? Thanks in advance
Old Aug 11, 2016 | 10:59 AM
99 GS3's Avatar
99 GS3
You don't have to have a leak for the heatercore to make bubbling/boiling sounds, air or blockage in the system could cause it to make the sounds. Can you pinpoint the sound to either be the driver or passenger side?
Old Aug 11, 2016 | 11:01 AM
Choosy's Avatar
Choosy
hey how's it going, it is comming from the driver side
Old Aug 11, 2016 | 12:22 PM
Choosy's Avatar
Choosy
New update, so the car is cold I let it sit , I turn the key to on and it makes that noise
Old Aug 11, 2016 | 12:37 PM
99 GS3's Avatar
99 GS3
well the heatercore is on the passenger side. are you hearing the noises the abs pump makes by chance?
does it sound more like it is completely inside the cabin, or more on the firewall?
Old Aug 11, 2016 | 12:42 PM
lexo98's Avatar
lexo98
If by "ignition is on" you mean it makes the noise while he engine is running check your coolant level. When the coolant runs low it pulls air into the system and you can hear it going through the heater core.
Old Aug 11, 2016 | 06:52 PM
bilgen's Avatar
bilgen
Could be the notorious "butterflies" from your HVAC actuators doing weird stuff. My 01 GS makes the butterfly noises but all the doors worked by these actuators located in the evaporator/heater core housing operate properly. Dunno why they make sounds when not being operated but I don't care either. As long as they work.
Old Aug 11, 2016 | 08:51 PM
Choosy's Avatar
Choosy
, yea it sounds more inside , I stood outside to try and hear it while I was hearing it inside but engine bay was quiet, I'll have to check it out
Old Aug 13, 2016 | 07:35 PM
Sportsfan2's Avatar
Sportsfan2
yes, i am not sure why those hvac actuators do that, but it does sound like boiling water.
pull glovebox and look at them while the noise is happening, do other selections of face only vrs feet or defrost and it goes away.
Old Aug 14, 2016 | 05:33 AM
sam12345's Avatar
sam12345
I vote actuators
bmatic01
Feb 28, 2023 10:58 AM
deanjohns
Aug 26, 2021 10:56 AM
JasotT
Jun 28, 2018 12:25 PM
lloydc
Apr 4, 2011 10:45 AM
e-man
Feb 8, 2010 09:50 PM
